Question about Konica Minolta magicolor 2430 DL Laser Printer
(the infamous) ?X toner not installed? error message
Hi, Friends.
I just replaced my black toner cartridge on a konica minolta magicolor 2530DL. Now I am getting (the infamous) “X toner not installed” error message for all of my toner cartridges.
I read in another post that I should clean the three prong device that makes contact with the cartridges. However, upon inspecting it, one of the prongs is bent or broken. Is this three prong device the problem? If so, how can I order a new one?
Thank you for your time!
  • Don C May 19, 2008
    when trying to work around this problem of "Black Toner not installed" I tried replacing the toner again but when I push the menu button after getting the "replace black toner" I get the message "Err Line 28"
I just got off the phone with KM tech support for the same problem with my 2430dl.  Take out the drum and remove the toner cartridges, then look inside the printer.  You will see a piece of glass about 6" long.  Next to it, on the right side of the printer, there is a little white plastic enclosure that contains three spring-loaded contacts; this is the sensor that reads the chips on the individual cartridges.  First, try cleaning the three contacts with a swab/alcohol, as well as the chips on each cartridge.  If this doesn't solve the problem, then the problem is likely with the sensor.  The part number should be 4139-6306-02, and it runs about $5. This should solve the problem.
Posted on Jan 26, 2009
    Problem Solver:
  • 5 Answers
I have the 2530DL, I was having trouble with the error "Cannot Rotate Cartridge." You can manually rotate the cartridge carousel as mentioned above, but if you simply stick a screw driver or letter opener into the hole on the right hand side (this is a switch that's pressed by the cover when it's closed.) The cartridge carousel will rotate freely. I was able to replace all my toners this way.  (the infamous) ?X toner not installed? error messa - ee258c1.jpg
Posted on Mar 25, 2009
  • David Taylor Jun 18, 2010
    My sensor prongs were bent and one of them finally broke and fell out. I found the part mentioned above on several websites. An alternative part number is: 8314139-6306-02. I found the part at Nationalparts.com, but with most sites they have minimum orders, so you will probably end up paying at least $25-30 with shipping.
    I ended up buying from Precision Roller. The 2530 model is very similar to the 2400 series and here's a link to the part schematic:
    http://printer.konicaminolta.com/service...
    I expected just to get the prong piece but it came with the entire sensor unit assembly along with the connecting wire.
    In hind sight it may have been easier to just install the little black prong unit, but since iI had them I decided to install all new parts. This required removing the side panel to chase the wire, but only two screws hold the side panel in place, one on the top under the cover and one on the rear. The cables are all secured with cable holders that are easily undone and re-secured.
    Snake the new wire through the hole in the side and run the wire along with the others to the rear. I had to remove a plastic piece under the fan to continue the run. The end plug should come out of the connector on the rear board easily, then reattach the new one. The plug fits into the connector on the board, don't try to pull the connector off the board, it stays in place and the wire connector fits into it. (I almost did this which would have been disastrous).
    The hardest part of the whole procedure is getting the assembly back down into it's proper spot. Pay careful attention when removing the old assembly and use some care since it is a light weight molded plastic. Two plugs hold the back side to the frame and three plugs hold the front side. I used a screw driver wedged between the frame and the rear two plugs to get them to clear then with pliers pulled the unit up and out. Now after I've done it, I think it works best to lift the assembly from the rear first, the front plugs are not as long as the rear ones. Now when putting the new one in just reverse the procedure. It also helps when getting the assembly into position to press down on the spring sensor, part of it has to fit under the carriage gear on the side. Put the rear plugs in first then GENTLY push the front down into place. I say gently because when I applied too much pressure on the front I broke the front plug off. I ended up having to use the old assembly after all! Needless to say I was very careful when pushing down on the front, you probably will need to use a screw driver to help shoe horn it into the right spot, it should just snap into place. That's it! Hope this helps someone! As far as repairs go, it wasn't that bad, just be careful with those plastic plugs!
I messed around with this for about 2 hours too.
(First replacing the empty black... then the "missing" Megenta cartridge.... then front door open... then back to empty black cartridge.. and again around the loop.....)
Then saw the mention of cleaning the three copper color contacts to the right of the little tab you use to remove the cartridge.
I pulled out the black cartridge and used a pencil eraser (careful not to get any little remnants in the works).
Then I FORCED the rotation of carrier (it clicks as you manually turn it, top away from you). Cleaned the Megenta, Yellow and Red . (There are three of these copper contacts on EACH of the four cartridges. For a total of 12 copper contacts to clean.)
When you clean... make sure the entire copper contact is bright copper color.AND make sure none of the pencil eraser falls in the printer. (I did this by having the vacuum by the side sucking the eraser pieces as I cleaned the copper contacts.)
Then forcing the rotating drum back to the empty area where the black cartridge goes...Careful..only 1-2 clicks to perfectly line up the guides on the left and right. If you miss getting it lined exactly, do not try to go backward.... rotate around again (.with the top going away from you ).
Now.... mine prints ok. Hope yours does too... .
Posted on Jan 11, 2009
    Problem Solver:
  • 6 Answers
In my case it looked as if the problem was from what looked like carbon (toner?) traces on the chip contacts of the yellow cartridge. Cleaned them of with 91% isopropyl alcohol as well as the sensor contacts and the other cartridge contacts which all appeared clean. Printer now works!
Thank you David Taylor for the hint about releasing the cartridge carousel! Those of you who are forcing the carousel risk damaging the unit, according to Minolta.
Posted on Dec 23, 2013
I had the same problem. I believe the problem is that the cartridges "misalign" and are not read. For example, mine kept reading that the magenta and black were missing but the printer would not turn the cartridges for me to get it out and clean it.
I pulled out the cyan which is the only one I could access...THAN you can easily manually spin the cartridge drum. I removed the magenta and cleaned around it although it was really not that dirty and put it back. It worked after that but it seems to be a continual problem.
Posted on Jun 20, 2008
I have an error message on my magicolor 2550 ( Konica minolta) that says Replace K toner??
The K toner is the black toner. The K stands for "Key" as in primary toner.
Pages 80-107 list the toner part number that you will need to order as well as how to remove the old and install the new toner.
Mar 15, 2011 | Konica Minolta magicolor 2550 Laser...
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
THE KONICA MINOLTA MAGICOLOR 2530DL/ ALL FOUR COLORS OF INK ARE LEAKING ALL OVER THE INSIDE OF THE PRINTER, WHAT WOULD CAUSE THIS?
Most likely reason is the printer is either a display model, or previously been sold and returned. The toner cartridges are usually sealed and these seals need to be removed prior to use. I would recommend returning to the supplier and asking for a new one, with the toner cartridges sealed. Once toner has been spilt, it is very difficult to remove all traces. A standard vacuum cleaner may be suitable to remove the worst.
Mar 08, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Jan 12, 2010 | Konica Minolta Magicolor 2450 Printer
I have replace the yellow colour and ever since the printer comes up with a error saying no toner
this is a very annoying error message
Konica Minolta Magicolor 2400/2500 series printer "X cartridge not installed" One of the most frustrating features of the Magicolor 2400/2500 series of printers is the very annoying X Cartridge not installed message
This error message can occur at any time with both original cartridges and or refilled cartridges. It is caused by either toner / paper dust covering either the chip on the toner cartridge or dust covering the chip sensor inside the printer. It can also be caused by a faulty chip reader inside the printer.
Nov 03, 2009 | Konica Minolta Magicolor 2450 Printer
I have to change black toner in my Konica 2530DL. Have never done it before. No one kept the manual and I can't figure out how to get the black toner cartridge out!! Help please.
press the up/down buttons on the printer till you hit menu special pages; press menu select button
press > arrow until you hit menu engine; press menu select button
choose engine replace toner; press menu select button
choose color to change and it will autorotate so that you can pull CMYK catridge out
Jan 20, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Jul 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Error 2408
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Jun 03, 2007 | Konica Minolta magicolor 2400 Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
3,885 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
