I HAVE A NEXXTECH NX2 PATA ENCLOSURE WITH A WD SCORPIO BLUE 8MB CACHE 320GB PATA 2.5IN RAW HARDDRIVE. I PLUGGED IT IN AND IT INSTALLED BUT THEN I RESTART MY COMPUTER AND IT GETS STUCK ON THE POST SCREEN SO I UNPLUG THIS ENCLOSURE AND I START BETIFUL AND THEN I PLUGGED IT BACK IN ONCE I LOGGED ON AND IT MAKES A FUNNY NOISE SO I READ ONLINE THAT PATA DRIVES NEEDED A JUMPER IN SLAVE OR MASTER SO I JUMPED IT THE WAY WD SAYS TO AND IT DIDNT WORK SO I PUT THE JUMPER IN EVERY SINGLE POSSIBLE POSITION AND IT STILL MAKES THE NOISE AND WONT WORK. THE HARDDRIVE IS STILL OK BECAUSE I CHECKED IT IN MY OLD PATA LAPTOP AND A UNPARTIONED, UNFORMATTED DRIVE WAS DETECTED SO WHAT IS THE PROBLEM
  • 11,800 Answers
It makes that noise because something is wrong with that hard disk mechanically - you need to test it. Install in a pc this
http://www.hdtune.com/files/hdtune_255.exe   - it's free
connect the disk to that pc and launch the program - it will automatically detect it - and perform an error test on it.
Posted on Sep 01, 2010
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Installing a new larger hard drive, and it will not accept it?
Wait a minute! Hold the phone!
HOW, are you trying to install this 320GB harddrive?
You cannot just grab a fresh, new harddrive, and put it in. There's no Operating System on it. It's on the 160GB harddrive.
(Windows XP?)
Not trying to 'sound' condescending, but I do not see anything to support that you know what you are doing.
If you are using a Western Digital 160GB IDE harddrive, you have a motherboard, and BIOS, that is past the size limitation for an IDE harddrive.
The size limitation was 137GB for motherboards, (BIOS program, actually), that had this limitation.
Size limitation isn't your problem.
Plus, LEAVE BIOS ALONE, as far as upgrading.
Why?
A) Power goes out while you are upgrading, and when asked, you do not save a copy of the original BIOS program, you can take your motherboard out, and use it for a Frisbee.
B) IF, there was a BIOS upgrade, AND it is NOT compatible, AND when asked you do not save a copy of the original BIOS program, you can take your motherboard out, and use it for a Frisbee.
Also, if it IS an IDE harddrive, and the old 160GB is an IDE harddrive, you cannot put both harddrives on that flat ribbon cable, AND use the 320GB as a Primary harddrive.
Want to use the 320GB as a Primary harddrive, (Master), and the 160GB as a Secondary harddrive? (Slave) There is a proper procedure.
No, I'm wrong? You have a fresh, new GENUINE copy of Windows, and are going to install it on this 320GB?
[Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
I hope it is Windows XP, (Home or Pro)
Why?
Because drivers are not be available for Windows Vista (Yecch!), or Windows 7.
What are drivers?
Small pieces of software that allow the Operating System to communicate with a device.
Windows XP and Windows 7, are just two examples of an O/S.
Harddrive, motherboard chipset, optical drive, (CD/DVD drive), audio (Sound), etc., are Devices.
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1460
Winfast is no longer in operation. No help from them.
(The motherboard manufacturer that made the motherboard for eMachines/Gateway. Confusing? Yes, I know.
eMachines sold out to Gateway. Guess what? Gateway SOLD OUT to Acer. Isn't this fun(?)
The motherboard is a Gateway MCP61SM2MA. Part number Gateway 4006232R.
http://support.gateway.com/s/MOTHERBD/Shared/4006232R/4006232Rnv.shtml
1) Has one Parallel ATA connector on the motherboard.
[PATA. Term is also known as IDE. Just to be more confusing, it is also known as EIDE. Enhanced IDE brought out by Western Digital, back in the day. The reason PATA is used, is to help distinguish it from SATA.
Serial ATA. This will help you understand,
http://en.wikipedia.org/wiki/Parallel_ATA ]
On the main Gateway support page I linked above, click on ->
Product Views.
In the list click on the blue -> Parallel ATA IDE connector.
2) The motherboard also has two SATA connectors,
http://en.wikipedia.org/wiki/Serial_ATA
On the Hardware Details list, click on the blue -> U - SATA connectors
Do not know if it is a PATA harddrive, (320GB), or a SATA harddrive?
Look at the label. Example on WD 160GB might be WD1600BEVT.
What is it on the 320GB?
Blank, new 320GB WD harddrive? BIOS isn't going to recognize it.
Why?
It hasn't been formatted.
WD does have a software tool to do this. Do I recommend this for a beginner? NO.
Better to install the 320GB in an economical external enclosure, and plug the USB cable from the enclosure into any available USB port on your computer.
Now you have a 160GB harddrive with WinXP on it, and 320GB's of extra storage.
Example (IMHO) of an economical external enclosure,
If you have no clue of what I have posted above, it is going to look like so much gibberish. Not my intent.
Not after 'Points'. Could give 2 cents.
{With this website you can rate ANY solution you see, and ALL solutions you see}
My intent is to teach. I have been at this for 8 years. (3 here, 5 elsewhere)
I want you to understand. Post back in a Comment, with the answers I need, from the questions I stated above.
We together WILL find a solution.
Regards,
joecoolvette
Jun 20, 2012 | E-Machines Computers & Internet
My WD Book was spinning and clicking constantly, so i unplugged the USB and the power source from my laptop. After plugging back in, it is no longer recognized on My Computer -- I've rebooted 2x. My...
Let's hope the spinning and clicking was caused by a bad circuit board in the WD Book, and not the Harddrive inside it.
To explain;
Inside the plastic external enclosure (Case) of the WD MyBook is an ordinary harddrive as used in a laptop, or desktop computer.
There is a small circuit board inside the case, that the harddrive plugs into. (Or there are wires from the small circuit board, to the harddrive)
The other end of the circuit board, has a USB cable attached to it.
The circuit board is an Interface Board.
It is this small interface circuit board that USUALLY goes out.
Harddrives are pretty tough, but they are a mechanical device, and are rated in hours of usage. They can fail.
What I would suggest is to buy an economical external enclosure.
Has the circuit board, USB cable, and everything needed, just needs the Harddrive.
Installing is easy. There are instructions included.
Now we come to the technical portion.
What size harddrive is it, and what technology does it use?
Size:
1) There are two sizes of Harddrives. They are measured across the Width.
A 2.5 inch harddrive is a laptop size harddrive.
(2 and a half inches across in width)
A 3.5 inch harddrive is a desktop size harddrive.
Once you open the WD MyBook case, and measure, you will know.
Pretty easy.
Technology:
Looking at the harddrives label, will tell you if it is an IDE (PATA) model, or a SATA model.
If no nomenclature is readily apparent looking at the label, there will be a model number on the label.
Put the model number in your search bar.
Example:
WD2500BEVT
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136387
250GB SATA harddrive. Also is a laptop size harddrive.
(2.5)
If you cannot find the information, just post the Model Number in a Comment, and I'll find out.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Example of a 2.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2781
Example of a 3.5 IDE (PATA) enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1337265&CatId=2779
The information on how to open a WD MyBook case, is not something the external harddrive manufacturer states.
For this we'll have to rely on videos that are made,
1) http://www.youtube.com/watch?v=6FlySnyJ0CQ
There are also other related videos to the right.
Regards,
joecoolvette
Oct 09, 2011 | Computers & Internet
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
