Question about B&K AVR-505 7.1 Channels Receiver
When i turn the center channel on the other speakers shut off
  • 52 Answers
Make sure the speaker is rated for your system. 4,6,8 ohms Your speaker should be rated equal or higher than the receiver.
Also make sure the speaker wires are not shorted at both ends
Posted on Sep 01, 2010
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
I had onkyo 5.1 hometheater i cant raise the volume more than 40 how can i fix the problem ?
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
May 28, 2015 | Onkyo TXSR309 5.1 Channel Home Theater...
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
Have Onkyo TX-NR808 receiver. Not quite 3 months old. Unit shut down when volume was turned up, but not drastic. Tried to adjust the db levels of my front speakers, in particular the center channel. As I...
The problem is the audio output ic's, one or more channels has developed a short causing the safety shutdown to engage. The only solution is take it back where it was purchased and since it is under warranty it should be repaired free of charge if not a possible exchange.
Jan 09, 2011 | Onkyo TXNR808 Receiver
No sound from center channel
If you have checked the speaker and wiring. Check the setup, the center channel could be off or it's not in a surround mode.
When playing a DVD through the receiver are the voices heard clearly in the front speakers? if so the center channel is turned off.
Oct 21, 2009 | Yamaha DSP-A1 Receiver
No sound from centre speaker on my Bose Lifestyle 8 series 2 system. I've checked leads and speakers by swapping them around. If it is the Acoustimass module which units are compatible?
Check your audio settings, via the on-screen menu. The center channel may be turned down. When set at -5 to -8, the center channel speaker may be practically inaudible. If raising the volume of the center channel does not solve the problem, then you do have a dead center channel. The system would then be in need of repair.
Sep 22, 2009 | Bose Lifestyle 28 System
Center speaker channel
This sounds like a bad connection inside the receiver. A 5 minute fix with a soldering iron and about 30 minutes to get to it.
If you can solder you should be able to fix this yourself.
Dan
May 23, 2008 | Yamaha Digital Sound Projector YSP-800S -...
Yamaha R-V98 Stereo Receiver
If you are running two low of an impedince (sorry i can never spell it right) or anything that runs under 8 ohms, which some speakers depending on the frequency will shut it down,
i have the same receiver and had the same problem,
it ended up for me that my center channel wasnt 8ohms,
the man A and B speakers will run ok at 4 ohms,
but the center channel is really picky,
hope i helped man,
you can contact me @ scottdilbeck@yahoo.com if you are still having problems,
or if that isnt the problem,
ive become familiar with mine inside and out
Dec 11, 2007 | Audio Players & Recorders
Power shuts off when I try and turn the volume up on the center channel. Center channel volume is very low and i can barley hear it. any suggestions?
Verify that you don't have a bad speaker in the center enclosure. Any change in there will cause an "impedance mismatch".  ...accordianman
Sep 15, 2007 | Onkyo TX-NR801 Receiver
Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Aug 30, 2007 | Onkyo TX-DS474 Receiver
B&K AVR-505 7.1 Channels Receiver Logo
47 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
