New TV Technika Mod. 32-630 Require code for remote control
premtech
  • 934 Answers
SOURCE: Need Code
Here's eight of the common codes for Zenith universal remotes, to control a Zenith Tv. : 101, 142, 149, 153, 154, 172, 177, 401
Hope this helps!
Bill
Posted on Nov 27, 2007
SOURCE: Sky remote codes
0065
Posted on Aug 27, 2008
SOURCE: technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Posted on Feb 22, 2009
SOURCE: technika sky code volume needed 42-502
the code for the new sky hd remote for my technika 42 -502 plasma tv that controls the volume is 0206 works ok now
Posted on Feb 15, 2010
  • 18 Answers
SOURCE: technika lcd19-408 sky remote code?
Have you tried 065,0065,0335 or 0649..?
Posted on Mar 16, 2010
Codes for tv technika all for one
These are the universal remote codes for Technica TV: 0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
Nov 26, 2012 | One For All Televison & Video
I have a fachi remote control and looking for a code for technika tv
Codes to check with Technical TV are:
Jun 18, 2012 | Televison & Video
How can i tune in a technika tv without the remote
how to retune my technika digital tv without the remote
Jan 29, 2012 | RCA Universal Remote Control
I've bought a technika tk51r all in one remote, an need the code for my technika tv 32-209
Hello
Three digit universal remote codes for Technica TV are:
000/ 001/ 004/ 005/ 008/ 009/ 013/ 042/ 046/ 053/ 058/ 076/ 105/ 109/ 170/ 174
Four digit codes are:
Five digit codes with RCA RCR 312W remote control are:
10054, 10180, 10150, 10060, 10092, 10016, 10056
OK.
Nov 26, 2011 | Televison & Video
Technika tv code for a universal remote?
Hello
OK.
Nov 22, 2011 | Televison & Video
I have been given a technika flat screen tv without the remote. I have bought a universel remote but technika is not listed in the codes could you give me a code for this tv please.
You should try codes for Funai, Symphonic, & Sylvania. Some Tecknikas are same as some of those. At least in my Comcast cable box remote code listings.
May 03, 2010 | Televison & Video
I have a Technika 32'' TV/DVD
my tv remote wont work i bought a new one but it requires you to enter a code and i dont have it. the tv is a technika 32-601 the codes 1484,0193,0363 dont work anyone know the right code
Nov 16, 2009 | Televison & Video
Require code for daewoo tv remote control is 4 in 1 technika
daewoo tv uses one of the following codes .. (for late model remotes .. earlier remotes only have 3 digits)
1004, 1005, 1006, 1014, 1015, 1016, 1103, 1137, 1151, 1223, 1253
if you have an older remote that requires only 3 digits .. then we can try to find that for you as well but sometimes the codes are not in the older universal remotes ..
Oct 03, 2009 | LG KU990 Viewty
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Need code for technika tv
i have bought a one for all tv controller and it doesn't have the code for a technika tv
Jun 21, 2008 | One For All URC 7740 Remote Control
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
