Question about Champion 2.4 HP Gasoline Generator
I have Tiger TG-2700 gazoline generator was working properly but stopped giving power ( nearly 6 Volt not 220 Volt as in real). I released 4 diodes connected on armature to test them but i think the problem is the 25 micro farad / 300VAC Capacitor. I just need to how that 4 Diodes are connected? I forgot the proper direction of one diode.
I have a tiger generator 2700, when u finish the choke it sound like it what to shootdown,what will i do
Posted on Apr 06, 2011
Neff gmbh microwave on but not heating
Step 1:
follow this steps and test and fix it. God bless you
1)Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testin
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Step 2:
Step 3:
Step 4:
Feb 07, 2013 | Microwave Ovens
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
My fridge will only work on 220 volts but not on 12v or gas anymore. the fridge worked perfectly then the gas stopped working one day, i discovered that the gas pipped was blocked, after unblocking it the...
Your refrigerator has a freon that we call R-717 which is amonia. You have to heat the amonia to have refrigeration. using the 12 volt side will cause power drain on batteries. If you had to close the gas valve most of the way down this is telling me that he gas pressure regulator went bad. The 220 volt heater is still working that is why this is working. change the regulator and you should go back to gas for operation. If the helps give me a rating please. thank you.
Apr 08, 2011 | Refrigerators
For these 4 control wires. How many watts do they consume. I have a generator 150ft away from the transfer switch, should these 4 18AWG control wires upsized?
No. They are fine. The voltage is 220. But the amperage is nearly nothing because its just for signaling the generator and switch when the powers out. I install, repair, and service generac products for a living.
Feb 10, 2011 | Generac 100 Amp 120/240-Volt Transfer...
I need a wiring diagram for coleman pm04350001 generator. the 220 recept. is not working and am trying to troubleshoot.
High no-load voltage Capacitor with high capacity
Check and replace. Low no-load voltage Speed to low Check and adjust rpm Faulty rotary diodes Check and replace Breakdown in windings Check winding resistance Capacitor with low capacity Check and replace. Proper no-load but low loaded voltage Capacitor with low capacity Check and replace. if wires are connected start with the Diodes first electronics parts stores will have these in stock as well as cheeper. hope this helps
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
Error 5b00???
1. Unplug the printer (NO power or any connection)
2. Flip the whole thing Up side down
3. At the bottom, you can see there are screws
4. they are for the generator of the power supply
5. Take them away
6. And slowly take away the "brown" box”
7. Then you will see a power cord links with printer
8. Use a very small driver to release it with real care
9. Leave it for 30 minutes
10. Put it back together .... done
After that
Also, from other, but work....
The reset procedure (for canon MP130) is:-
Turn on the machine
(1) Press MENU
(2) Press SCAN COPY SCAN to enter service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
DONE !
Aug 06, 2010 | Canon MX300 Office All-In-One Printer
Have an fg5700ak runs ok but no power output what
Typical diodes are 10 amp for these. The stator and rotor both have VERY low resistance readings. The reading typically will be below that which will register MEANINGFULLY on the digital meters.
My generator had 10 amp diodes with surge protectors across them. One of the protectors shorted and generator output was zero. Mine is a 6KW diesel silent unit.
Replaced the diodes with 70 amp ones with surge protectors that have 20 times the energy absorbtion as the originals. Unfortunately this required some lathe work to make holders for the diodes and the surge protectors to ride on the rotor.
Used the light bulb trick to remagnitize it once diodes were replaced.
Nov 10, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
I want to make my 110 volt generator into 220 volt
most generators have a 220 volt plug on them from the factory, if it is a small one it might not have the capabilities of 220. If it has the 220 plug then you will just need to wire the proper 220 male end onto whatever you are trying to run.
Oct 25, 2009 | 2003 Yamaha YZ 125
I have a Coleman Powermate 5000 / No power output
Two suggestions. One: check for voltage from the secondary coil wires (if it has one). Two: unless stated do not do this, I have always flashed the excitor circuit through the 120vac receptical. Give these a shoot and I hope it works for you.
Mar 30, 2009 | Coleman Powermate Powermate 5000W...
Run ac off of generator.
you need to use a volt meter and test which lead from the 4 wire output of the generator a 220 v is coming out.
the round center prong of the ac is its ground and should not be connected to any live power. it could be left unused.
tnx 4 using fixya,
drcool
Sep 27, 2008 | Hampton Bay HBLG5004 Air Conditioner
Champion 2.4 HP Gasoline Generator Logo
552 people viewed this question
Top Champion Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Champion Electrical Supply Expert? Answer questions, earn points and help others
