Question about LeapFrog Tag Junior Book Pal Purple
My computer can't detect the leapfrog tag junior.. what should i do?
I had the same problem. Sat in front of the computer for an hour trying to figure out what was wrong. In the end I unplugged the usb cord and plugged it into another usb outlet and it worked. Perhaps you could use someone else's computer? It seems that the usb connection is quite unpredictable.
Posted on Dec 24, 2010
I installed my leapfrog connect for my Tag reader. It says to plug in the Tag with the USB cable to the computer ( which i did) and turned it on. For some reason its not picking up so i cant go to the...
it depends on what Operating system your using, if xp then goto devices in the control panel and click on detect new devices, also check there if the usb drivers are installed, sometimes you have to install the software before plugin it in. if it's win7 then again click on devices and also check my computer when the usb is connected, and again install the software before plugin it in. best regards.
Oct 30, 2013 | LeapFrog Tag Reading System
Having and issue with the audio download on the Leapfrog Tag system. I have Leapfrog Connect installed on my Mac. Audio for books previously downloaded and newly downloaded are not able to be put on pen. I...
Just got this from LeapFrog. Worked for me, although it toook a couple of attempts.
For Macs:
Please try downloading and running this tool and connect the Tag Reader when prompted:
http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
For Windows machines:
1. Close the LeapFrog Connect application.
2. Double-click on this link http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe then click "Run."
3. Click "Unzip" to extract the files.
(You will be asked for a location to save the files. Save them to your Desktop or to another folder that you can easily find.)
4. After the files are extracted, find the "LeapFrogTagFixTool" folder on your Desktop (or where you saved the extracted files).
5. Open the folder and double-click the "TagFixTool.exe" file to open the LeapFrog Tag Repair Utility program.
6. Connect your Tag Reader to the computer. (Make sure your toy is powered on.)
7. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
8. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Jul 26, 2012 | Toys
My tag reader won't say my child's name
The two responses to this question have nothing to do with the question! I have a similar problem. I have a brand new Tag, connected and uploaded books just fine, but in my case it doesn't say any name when turned on/off.
Apr 03, 2012 | LeapFrog Tag Reading System
Audio wont download onto tag junior
make sure leapfrog connect is installed correctly, then make sure you have the latest version of flash, after you download the audio, make sure you add it to the tag junior. you can do that by clicking "on my tag junior" on the left side under audio downloads and click add then it will sync.
Dec 26, 2010 | LeapFrog Tag Reading System
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
Jul 02, 2010 | LeapFrog Tag Reading System
I haven't gotten past the setup screen because it
You need to contact the seller. The device has a detection problem, which is not something you can correct, unless the toy has instructions for how to reboot it. It sounds like a defective sensor.
Jan 24, 2018 | LeapFrog Tag Reading System
LeapFrog Tag Junior Book Pal  Purple Logo
861 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
thegtw
relojmesa
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
