Question about Acer Aspire 9300 Notebook
Aspire 9300 will not recognize new battery and doesn't seem to want to charge those that if does recognize. Any solutions?
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 08, 2010
BATTERY DOESN'T CHARGE ON MY ACER ASPIRE ONE MOD#KAV60
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
May 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
Aspire 9300/7000 series fails to charge the battery. I need a new motherboard or a properly repaired used one. Can this seventy- nine year young senior find a solution, for this problem
sir 1st check the charger DC output if the charger is OK the battery pack no charging u need to re-pack the battery pack or replace the battery...Thanks and Good Luck..
May 23, 2009 | Acer Computers & Internet
My Aspire 9300 no work anything
Did you recently change or add memory? My 9300 will not recognize 4GB RAM after I upgraded the BIOS to version 1.2, so I use only 2GB and it works ok again.
Apr 27, 2009 | Acer Aspire 9300 Notebook
My computer will not recognize the battery. Runs OK on AC.
Since the system is not seeing the batteries the apparent fault is the motherboard connection for the battery. If under warranty , contact Dell, in not, you can try and purchase a replacement motherboard on EBay.
Apr 26, 2009 | Dell Inspiron 9300 PC Notebook
9300 aspire notebook webcam not working
hi there, i had the same problem back a few month ago. the solution for me was, i twisted the built-in camera 180 degree a few times, after that, i heard sound indicating my system found a new hardware and it started to install them, which in my case, the webcam ^_^
maybe the connection is the problem, mine is acer aspire 5580 laptop.. hope this help
Oct 29, 2008 | Acer Aspire 9300 Notebook
Acer Aspire 9300-3716 Hardware trouble after downgrading from Vista to XP.
You can download the drivers directly from Acer.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7293&areaid=7&website=AcerPanAm.com/us
Just choose "drivers and downloads"
Then "notebook"
Then "Aspire 9300"
On the right window, you will see available drivers. Once you highlight each one, you will see what operating system it is for in the "download details" window.
Feb 11, 2008 | Acer Aspire 9300 Notebook
Won´t charge
My SLVR had the same problem, so I bought a new one from Amazon. When I plugged the new one in the first time it did fine, but when I ran the battery completely out, it wouldn't charge. I played around with it a little bit, and I think I've found a solution that works: try taking the SIM card out of the phone, THEN charge it. It works on both my new one and my old one that way. The drawback for you is that you can't use your phone while its charging, I just switch phones while the other is charging, a bit of a pain sometimes, but the SLVR is my favorite phone so its worth it. :-) Good Luck.
Dec 10, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Acer Aspire 9300 Notebook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
