Question about Amana ABB1927DE Bottom Freezer Refrigerator
We have a 15 year old Amana refrigerator with bottom freezer and would like to know its capacities (top and bottom) Model Bx2055W
aborcass
  • 2651 Answers
SOURCE: ICEMAKER NOT WORKING
that connection is made behind the cabinet, trace the wire back. but beforeyou do, the freezer light switch must be depressed for voltage to appear. the uint will not make ice with door open. so push in the light switch and ck again
Posted on Mar 23, 2008
huuum
  • 750 Answers
SOURCE: 11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Posted on Oct 05, 2008
Sea Breeze
  • 4655 Answers
SOURCE: amana ABB1922 refrigerator - refrigerator not cooling
Check fan for operation and vent duct for ice or the damper sticking between the two compartments. It does not take much when the freezer is on bottom, colder air (because heavier) remains there without proper circulation. I will be trying to find the maintenance /service manual to help resolve this. JT
Posted on Feb 04, 2009
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
  • 20 Answers
SOURCE: amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
Posted on Jun 04, 2009
Do you know the capacity (cf) of the amana br22tw,please?
The capacity is given in cubic feet, yours is 22 cubic feet. Note the 22 in the model number that denotes this BR22TW.
Sep 16, 2011 | Amana BC21V1W Bottom Freezer Refrigerator
My refrigerator & freezer are not keeping things cold/frozen unless the items are in the very back of the unit. I have been told it could be the defrost timer. I have the Amana fridge with freezer on...
Might try defrosting the unit manually,this will let u know if possibly bad defrost timer or heater,or thermister on condenser behind freezer panel try YouTube put in model number,should link you to an APV video.
Dec 27, 2017 | Amana ARB9058CS Bottom Freezer...
There is a strong acrid odour coming from my Amana refrigerator. This frig is 15 years old and has a top freezer.
It may be a refrigerant leak in the coil and it will stop working soon. When this happens it's time for a new box. 15 years is a good run.
A new coil could cost as much as a new frig and that's without labor cost.
I hope this helps
Aug 23, 2010 | Amana Refrigerators
Noisy refrigerator
hi doug,
with the amana of that age there are several weird noises, be glad you have only one. that aside
ill tell you all of em...
a clear pop..... usually after defrost its the compressor starting cold as they say.
a knock ( very much like you should answer the door) is the plastic liner popping back into place in the freezer, after defrost.
Then ther is the knock of the water solonoid, but that would be more than once a day.
you might be able to remedy these, by changing the box postion a bit,,, i know sound stupid but i was the old lonely for 15 years and this one was always tough to diagnos it never happened whiles the service guy is there.... so i bought one....
Oct 03, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Can I get a set of black gaskets for my 15 year old Amana ?
Go to an auto supply store, one that the professional autobody guys use. They will have black paint that works on gaskets.
Jun 03, 2009 | Amana ABB2227DE Bottom Freezer...
Mar 16, 2009 | Amana ABB1927DE Bottom Freezer...
Hello dunc444444
Welcome,
Huuum {
Let me know.
Huuum
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
382 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
