Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV Model KV-Hp212M83
TV shows No Signal even when i connect my cable adapter.
Please solve this problem.
And one more. What is the warranty and guarantee duration.
My tu Serial no: 6203701
    Problem Solver:
  • 8 Answers
I am not sure about that one if it is a direct view tv i thing you may have a problem with we may call xbox wich is integrated inside the tv wich is by the way very expense you may want to check with your authorized sony service center
Posted on May 10, 2008
SONY TV trinitron model HP212M83 colour is fault, red light blinking 5 times when TV is working, please solve this problem
If you wish to get more details visit the site linked here. Blinking codes of many popular brand TVs are given. Pull up older posts. http://electronicshelponline.blogspot.com/
m
Jan 27, 2017 | Sony Televison & Video
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
Sony wega 21 inch tv kv hp212m83 flyback transformer number
Contact the authorized service center for Sony to get more details.
Electro help
Aug 20, 2014 | Televison & Video
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron WEGA TV 21", Model- KV-HP212M83, brought 4 years back and till now not a single problem. But today morning when I power on TV, it is not getting on. I checked all my power...
If your plug points are getting power, then follow as listed below.
Open the back cover carefully. identify the screws with a torch light, remove them.
You may have to remove two screws holding the audio video socket panel. This
is in the back panel. TV weight is on the front side. Hence guard it. By chance
by applying pressure on the screw driver it may fall off!!
Follow the power wire and check the fuse. It may have a small cover where the
fuse is secured. Remove the cover and take the fuse out.
Just view fuse in light. If the wires are parted apart, replace it. same type and rating.
Oct 08, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Connecting DVD player to Sony trinitron KV-20DVM30
Your description of your set sound like it is a mono set. You should be able to plug in the yellow and the white connectors and get sound out of both speakers. On most sets, if there is audio on the left (white) wire it will produce sound from both speakers.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 01, 2009 | Sony KV-20VM30 20 in. Combo
No cable channels at all on old Sony Triniton
make it sure that the coaxial cable has its own signal! if your tv has a raster (sometimes blue) and it says that the tv is good, but if there's no channel at all then the problem is in digital converter or the connection of the coaxial cable comes from..you can also try auto programing but if the problem still occured then contak your cable subscription channel
Apr 03, 2009 | Sony KV-13M10 13" TV
Is my tv digital?
It is not a matter if your TV is compatible with a digital signal, it is the signal being offered to the TV.
Meaning, if you are using Cable TV, you are fine and need no further action because the digital signals are already converted by the Cable Box into either an analog TV (RF) signal, or a PBR (RGB or Comp.Video) signal which the TV understands via a separate input (external video input).
Feb 14, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No signal
Check is RF Antena/ Cable connected? If yes, go to TV Menu and select Auto-Program. TV will start tuning and search all available channels on cable/ on-air. If there is no channel reception, TV has defective Tuner. If you know basic electronics knowledge, replace the Tuner or contact nearest Sony repair shop.
Jun 04, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
