Question about Maytag MTB2156GES Top Freezer Refrigerator
My matag problem.......sounds like a small gun going off. It comes from the freezer...about once a day. Thanx......David McCarthy
    President:
  • 1,891 Answers
This is a problem with the way the cap tube has been installed . and it may be under factory warranty . ck the age of unit . you can also call maytag with model and ser # . the only to correct is to change the line to comp or compressor itself .. mm
Posted on Sep 01, 2010
Fridge not cooling freezer is working defrosted for 48 he's and it worked for only 4 days
Take everything out of the freezer. Unplug the unit. In the back panel inside the freezer remove the two screws that hold the back panel in. (If you have an ice maker remove the 4 screws holding it in and disconnect the wiring harness.) once the panel is off yo can see the fan. It may have come unplugged. If its plugged in good the plug the frige up to see if the fan comes on. If it does then the holes from the freezer to the fridge are clogged. If it doesnt come on replace the fan. The fan may take a minute to come on so dont jump the gun.
Jan 10, 2016 | Refrigerators
Matag msd2651kes side
Sounds like you need a new defrost control/timer.
Mar 01, 2014 | Maytag Refrigerators
Matag Mod. MSD2554ARA leaking water on the floor
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill.
Apr 25, 2012 | Maytag Matag 25.6 Cu Ft Side By Side...
It's a side by side refridgerator the freezer get's water at the bottom then freezes and leaks out the freezer door. i clear the ice out, it come back in a few day.
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Jul 24, 2009 | Refrigerators
My LG bottom freezer, french door evaporator fan ices up andmakes a loud buzzing sound. I have to unload the freezer and defrost with a heat gun. Lots of frost around the fan.
Defrost heaters are not coming on. Check with multi meter..is it frost, or ice freezing under the fan-blades. That my friend is a blocked drain hole. Otherwise ohm out defrost heater should read 30to69 ohms of resistance. Timer may be stuck, or a hi-temp safety switch is not closing (a small disc at the top of the coils) when it comes out of defrost. Carweful with that gun, Jim! Too much heat warps all that chinese plastic. Chris in bigbEar
Apr 20, 2009 | LG Refrigerators
Water builds up in the bottom of freezer
had this happen once and my drain was clogged. in the freezer section you have to remove the rear panel. 2 1/4 screw bolts. after exposing the coils the drain hole is in the middle. i clesred the hole with my wet/dry vacuum. first sucked then blew air through it. hasn't done it again and its been 1 year so far
Apr 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leaking from inside freeze.....
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water leakage under freezer door-ice on bottom of inside of freezer
Oct 27, 2008 | Maytag MSD2758GEW
Maytag MTB2156GES Top Freezer Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
