Question about Home
Leaking water tank refils about every 15-30 min.
  • 28 Answers
Check the flapper inside the toilet tank for alignment or you may need to replace flush valve unit.
Posted on Sep 02, 2010
Why does the water valves continually pulse?
It's hard to answer such a general question. I will assume your reference refers to a toilet, and that 'pulse' is regards a recurrent slight refill action of the tank fill valve. If this is the case the cause is probably a slowly leaking flush valve. When the tank water level drops enough to activate the fill valve, there will be a slight refill action (pulse) to top up the tank water level. It will repeat until the leaking flush valve is fixed.
Jun 06, 2015 | Home
Tip
Our commode isn't leaking, yet it refills many times a day
If your commode is refilling over and over, you may have a Ghost Flushing problem. Even though there's no water on the bathroom floor, you likely still have a slow leak somewhere in the tank. To locate and identify the source of the leak fill the tank and shut off the water to the commode. Remove the tank lid and draw a pencil line along the top edge of the water line. Leave the water turned off and go back several times and redraw the pencil line at the water line. When the water stops draining see where the water level is. If the water has stopped just below the overflow tube, you likely have a siphoning problem. If the water drains to the bottom of the tank you likely have a flapper problem.<br />To correct the siphoning problem reset the the depth of the fill tube in the overflow tube. Fill the tank up, shut the water off, and recheck after some time. Repeat these steps until the water stops draining.<br />To correct the flapper problem gently lift the flapper and clean the bottom of the flapper and the flapper seat. Refill the tank, shut the water off, and recheck later. If water still leaks replace the flapper.
on Dec 28, 2010 | Plumbing
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
Hot water tank leaks, big time, as it refills, stops dripping
If the leak is from the tank itself, no you can not fix it. If it is a supply pipe and the leak is visible, in most cases yes. I would recommend you have this issue resolved very soon. If the tank has sprung a leak, it will be a matter of time before the leak becomes a flood.
Feb 03, 2010 | Plumbing
When flushed the tank refills and the float goes up.... after about 5 mintues of quiet, there is a "shhhhh" refill sound..and bubles inthe water from the main pump. how do I fix this? 6 LPT and 1.6 gpf
Adjust the water level in the tank to the water level line in the tank. If the water is spilling into the open tube in the center of the tank, that will cause the water to run.
If water is not seeping into the tube, then maybe water is leaking through the rubber stopper and into the tank. You will have to replace that rubber stopper
Oct 23, 2009 | Eljer Toilet Onepiece Canterbury ...
Water Heater drain leaks and has caused rusting on tank
If you're sure it's the DRAIN, just get a garden hose cap for it (your other option is to replace the valve - drain tank, replace valve, refill).
NEVER CAP THE RELIEF VALVE DRAIN!
Sep 18, 2009 | Fasco Bradford White Hot Water Heater...
Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
Air innovation humidifier KS30U-06C leaking
check the o-ring seal in the bottom , they like to get crossed up when you pull the tank out to refill. a little vaseline will help.
Mar 30, 2008 | Heating & Cooling
Home Logo
49 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
