Question about Whirlpool Heating & Cooling
Breaker on window air conditioner tripped, i reset it and its now holding but the air conditioner now only blow's warm air and a alarm inside the unit go's off about every 10 sec, any ideas??
    President:
  • 1,515 Answers
Hi, the only part on your unit that will draw enough amps when it has a problem, is the compressor. It must have overloaded and exceeded its R.L.Amp's to trip it. Now that the breaker is holding and you have no cooling, I would say that the windings in the compressor are not shorted to ground, but are open internally inside. There's not much you can do about this problem. It may also be open on its external overload protector. Here's what you can try anyway, to see if you can get this unit back on line only if the overload on the compressor is open, turn the unit to fan only to at least have air circulating, or just unplug it. Take a garden hose outdoors and wash out the condenser coil to remove all of the dirt. This will cause the compressor to over load and the system to build up high head pressures that will trip the main a/c breaker. Wash it very good. Let the compressor cool down, this may take several hour before it will reset the over load. You can turn off the breaker and if you can see the compressor from out side you can run cool water over it to help it cool down. Let it dry good before turning breaker back on. When you are ready, turn it on and listen for the compressor to come on from outdoors, it will make a fairly loud humming sound when running. If it does nothing, either the run capacitor is faulty, or the compressor has open windings if it doesn't run and the breaker holds. If breaker trips again, the compressor reset, but is shorted or has a locked rotor. It wouldn't be worth the $$$ to have a tech out to charge you an arm and leg to tell you what I am telling you, it would be better to price a new a/c. I am just being honest with you and trying to save you some $$$. Please keep me posted on what you will do, as it will take a meter and gauges to trouble shoot the unit, but from what it is doing, I am confident it is your compressor as the alarm is telling you there is a problem. Most a/c companies will pull the unit and take it to bench it and the hours build up very fast. For the cost of a compressor and the labor to R & R would buy you 2- new units. I know this is frustrating as it is for me to give you this news. You can call around to see what they will charge to come out to see, but I am sure you will end up with a large bill and the unit will still be down. Please don't forget to rate me as I know you will be kind, and keep me posted after you wash this coil to see if this compressor starts. Be outside and have some helper turn it on so you can listen for it to kick in. Please let me know.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 01, 2010
  • jstokes555 Sep 04, 2011
    Thank you very much Shastalaker7! A very good start for me.
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
My central air conditioner is just blowing warm air ..it is not cooling ...
Is the out side unit working ? check the circuit breaker if it is tripped your going to need service they trip for a reason hope this helps . Tom
Jun 29, 2009 | Heating & Cooling
Breaker box clicks on then air conditioner still running but warm
When you say breaker box clicks and then warm air, are you referring to the actual breaker switch in your power panel, or clicking at your ceiling assembly? When the breaker trips, the air conditioner should shut down completely, is that what happens? The compressor kicking in and out could cause circuit breaker to trip. Did the electrician record incoming voltage supply, and what was it ? 115 volts?
Jul 12, 2010 | Dometic Rooftop RV Air Conditioner
My amana ac unit over heats the circuit breaker and trips it off after running for about 15 minutes. It will not blow the fuses on the outside disconnect next to the unit outside.
What you described 'shouldn't' be happening - "if" the outside fuses and the inside breaker are sized correctly for your air conditioner.
I would make sure that the fuses in your outside disconnect were the proper size (for your AC), and that the inside breaker was of suffienct size to handle the air conditioner, and whatever else might be on the circuit.
Note: You would never want the 'outside fuse size' to be bigger than the inside breaker.
For example: 50 amp fuses in the outside disconnect and a 40 amp inside breaker is a no-no.
Often, for whatever reasons - someone will put larger fuses in the outside disconnect than what is called for.
When this happens the inside breaker is the only safety on the AC.
The problem is - for whatever reason - your inside breaker should not be tripping off.
It's likely that the AC may be on a inside breaker "that also has other things i.e. dryer, electric range or Refrigerator," and therefore any of these components 'including' the air conditioner could be causing the inside breaker to 'trip.'
One way to check this would be to 'un-plug' whatever else you had on the inside breaker - and then run your air conditioner and see if the breaker trips. Let's say you have the refrigerator and the air conditioner on the same inside breaker. You suspect the refrigerator is causing the inside breaker to trip - so you unplug it - and then turn on the air conditioner. "Now" it does not trip the inside breaker and assuming you have the proper fuses in the outside disconnect - you could safely say the air conditioner is ok - but - the refrigerator might be on the blink.
It's also possible that you just have too much on the inside breaker and you need to plug the refrigerator in to another outlet.
Still, if it was me - I think I would really think 'hard' about calling a Service Tech out - and let him/her diagnose the problem.
Hope this helps.
Jun 12, 2010 | Heating & Cooling
The air conditioner was working today i have a RUUD UAKA018JAZ, the fan is running however it is not blowing cold air out the vents
Hi, your problem is in the unit outside. Check to see if the fan is on, make sure the compressor is running also. If nothing is on, check the breaker to see if it tripped. Also, the box at the unit has 2- fuses inside behind the plastic cover you can't see unless you remove it. If the unit is off and the breaker was ok, remove the cover and replace BOTH fuses. Do all of this and let me know. If the breaker keeps tripping or blowing fuses if the unit was off, you have a componant shorted. It may be off or on and not cooling well due to a loss of freon. If it is on, hold your hand above the fan to feel the air. It should be nice and warm almost hot if its hot outside. Let me know what you find please. We can find the problem.
Sincerely,
Shastalaker7
Jun 12, 2010 | Ruud UAKA018 Air Conditioner
Heatpump blow out air put not warm
We will need to check and see if the outdoor unit is running when thermostat is set for heat. If not, check the circuit breakers and reset if tripped. Also, check to ensure the high pressure switch isn't tripped (you will likely need to open the panel to see the HPS, it will have a red button on the top of it.
Mar 22, 2010 | Heating & Cooling
The window unit has ran for 3 years never tripped the breaker now it only trips the reset button on the cord does not trip the breaker when i reset it it works great for a while it stormed the night it...
well they do go bad was it eclectic storm it might have fired it. but make sure the unite is clean both front and back if have air compressor blow it out,Ok! hope this helps Paul
Jul 06, 2009 | GE AVX10AD Air Conditioner
No cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
Jul 02, 2009 | Amana Heating & Cooling
Ac blowing hot air , help me , umemployed and broke and hot
check your circuit breaker be careful resetting stand off to the side if tripped the breaker tripped for a reason. you going to need service. i know its not what ya wanted to hear.
Jun 23, 2009 | Weather King 10AJA3601AH Air Conditioner
Breaker tripping on electric furnace.
First, how old is that breaker and are the connections all clean and tight?  A warm breaker is normal.  If it hot or buzzing, that is another story.  If the breaker is more than a few years old, it may pay to invest in a new one.  They do wear.  If you have a connection which has come loose or is corroded, it will trip the breaker, arc at a connection point or even cause a coil to fail.  Dirty connections heat up and actually back off the holding bolts to the point of failure or to tripping the breaker with arcing.  With the breaker off, inspect all connections from the panel to the unit.  You may get some surprises.
If none of this turns up a problem, inspect the actual heater coil, you may find dirt in there which is causing a problem or the unit itself is failing and touching a grounding point.
Dec 22, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
145 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
