1.Remove the two screws from the base
grille at the bottom and remove the grille.
2.Unhook the front edge of the drip pan and
pull it out the front of the refrigerator.
Reach under the front of the refrigerator
and check the water tubing, nuts and the water valve which is as you have mention white and one of this part become loose and their you have the water leak.
You can pull up the refrigerator on the front side in an slightly icnlinate position by using temporary addition wood legs so you will have a more space for you to work on. However special care must be taken not to bend too much and fall behind.
Yes corect the hook is secure with rivers. Unhook mean that you can push down the drain pan shlightly bended since it is plastic and then pull it out all the way out like a drawer.
Your correct the linking if from the water system, as we have mention you can check the white water tuping parts, nuts, tubbing and water valve and tight them up since one might get loose.
Good luck and thank you for using FixYa, please also remeber to vote for us
There is a white part in front of the drip pan that is bolted to the front rim of the refrigerator bottom. This would need to be removed for the pan to come out the front. The pan seems to be full because there is some kind of leak in the water tubes.
We have more problems than we thought. We'll get a repairman. Thanks.
