I have an e system PC model - Ei 106/Ei 206/Ei 306, the problem I am having is that I cannot get it to boot up. When I switch on the PC all I hear is a long intermitent beep. I also get a screen mesage saying - RGB no input signal. I dont know if they are related. Any suggestions would be greatly appreciated. Regards Alan Frost
  • Bob Sep 01, 2010
    Hi The problem you're having,and hearing,is that your video card is not working correctly.Can you tell me if you have on-board video,or if there's a PCI,AGP,PCI-E etc video board added? Thanks Bob
  • bigal218 Sep 02, 2010
    The motherboard is a FOXCONN it would seem that it is built in as I there are no other cards added to the system.
    Regards Alan Frost.
  • 245 Answers
In that case,the easiest fix would be to add a PCI or AGP card,depending on what your board will accept,and what your needs are.PCI-E are the cards most people are using now,and the real gaming versions can be very expensive.
If you add a video card,just make sure to turn off the on-board card in BIOS.Then,other than loading drivers,you should be ok.
You may want to make sure your RAM sticks are fully seated while the case is open too.
Bob
Posted on Sep 02, 2010
Why Do Interfaces on an ES5D000X4S01 Subcard Fail to Go Up When the Subcard Is Installed on an S5700 Switch?
An ES5D000X4S01 subcard can be installed in the front card slot of the following S5700 models: S5700-28C-SI, S5700-52C-SI, S5700-28C-EI, S5700-52C-EI, S5700-28C-PWR-EI, S5700-52C-PWR-EI and S5700-28C-EI-24S.
An ES5D000X4S01 subcard can be used on a switch only when the switch and its rear subcard ES5D00ETPB00 run the PCB versions. If the PCB version of the switch or ES5D00ETPB00 is not listed in the table, interfaces on the subcard cannot go Up.
May 26, 2016 | Computers & Internet
My Dell Precision 360 PC does not recognize HDDs.
Sorry to hear you are having problems with your Dell Precision 360. If you are still having problems let me know.
Please describe what happened, what symptoms, you experienced prior to the system "dying". Also, what happens when you power on the pc now? Does it ask you to press F1/F2 keys to continue or does it give you options- for example something like startup repair, start in safe mode, etc. ?
Have you tried shutting system down and unplugging power from pc for two minutes then plugging back in and powering on?
Have you tried booting from a different hdd?
If you have tried anything please let me know what you tried and the result.
Good luck.
Oct 21, 2014 | Dell Precision 360 Workstation/Personal...
Ei System 4411
Here's one link for your solution:
http://www.crucial.com/upgrade/Ei+System-memory/Ei+System+-+All+Models/4411-upgrades.html
Mar 31, 2014 | Computers & Internet
Ya if i only could reload win7 and yes u will lose all info on hdd even the dummy password he put on to lock hdd amazing only thing it wont reload windows
Step 1:
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Step 2:
For Windows users who switch and upgrade from Windows Vista, one difference will be immediately noticeable when installing or upgrading to Windows 7, i.e. Install Windows 7 setup wizard no longer prompts or asks for user selection of which edition of the operating system to install. Instead, each Windows 7 DVD disc or Windows 7 ISO image will automatically install the preset specific edition which it's confined to.
Although Microsoft does not provide an universal "one disc rules them all" Windows 7 installation media, however the function is indeed supported. User just need to delete and remove the ei.cfg from any Windows 7 ISO disc image to convert the image into universal disc of any edition Windows 7 installer. For user who has the ISO image of Windows 7, and wish to make it an universal installer for any and all supported editions of Windows 7, as shown in illustration below, now has an easier way to modify the ISO. Instead of manually unpacking and extracting the content of ISO image (or copying files from DVD) to HDD, deleting the ei.cfg and then repacking or rebuilding installation files back into ISO to burn, user can now eliminate troublesome procedures by making use of "ei.cfg Removal Utility". clip_image001.jpg The ei.cfg Removal Utility is a simple tool that will disable the ei.cfg from any Windows 7 ISO disc image, thereby converting the image into a "universal disc" that will prompt the user to select a preferred edition during setup. ei.cfg Removal Utility works directly to patch the ISO image, by toggling the deletion bit in the UDF file table to instruct the operating system to ignore and remove ei.cfg, or treat it as if it does not exist. Best of all, ei.cfg Removal Utility can reverse the patching to restore the ISO disc image to its original state when the tool is been used to apply on a disc image that previously been patched by the utility. ei.cfg Removal Utility is a standalone portable app, and thus no installation required. In fact, the program does not have much user interface. After selecting the target Windows 7 ISO, the disc image will be patched right away. So make sure a copy of ISO backup is done. Download ei.cfg Removal Utility: eicfg_removal_utility.zip
Feb 14, 2013 | Computers & Internet
Seriously, how do I access bios on E System ei 106 x86 computer?
for some systems, you need to press delete and others it is F2 but have a look while booting up..it normally says it.
Dec 18, 2009 | HP Pavilion dv7-1130us laptop
What company makes the ei system laptops
What is the model number?
The manufacturer is either EI System or EI Systems. The model number is crucial to isolate which of the the two. One is US locate and one is English.
Oct 12, 2009 | Computers & Internet
Gateway Computer, model CX2619 will not start
have you done any upgrades
EI memory or windows
Jan 22, 2009 | Gateway CX2619 Notebook
The laptop will not turn on
HAVE YOU DONE ANY UPGRADES EI/MEMORY OR VISTA
do you hear thefans running
how old is the system
Jan 21, 2009 | Dell Latitude D600 Notebook
Ei systems 4411 wont power on/mains or battery power
If the fan does not spin, the unit is shutting down to protect the processor. I would have the fan replaced . Do not attempt to use the laptop, it may cause extensive damage if it overheats.
Joe
Oct 30, 2008 | Computers & Internet
Im after a user manual for ei systems 4411 laptop i need to locate the battery
Hi, as far as a manual, I googled all over the place with no luck. I did find this, not what you wanted to hear. I don't know that particular model so I can't tell you where your battery is, sorry. Mechanic
http://support.thetechguys.com/layout.aspx?ID={0575f203-9450-4588-b670-618e5c6cc804}&CatID={47986c22-40fc-4c5b-ae38-a68874fdb04f}
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
798 people viewed this question
David Payne
David Payne
