I just bought Acer Monitor X213W 21.6 inches There are three cords, one for Electrical supply, one for computer attachment, the third wire is for a particular purpose goes one end to the monitor and other end to the socket of Computer.I have Pentium 5 dual core 1.8 GH new computer but did not find the socket which the thirs wire cann be attached. This wire has 2 sets of 9 pin and a small horizontal pin. What should I do now?
  • 3 Answers
One is power one is standard vga and one is a dvi cable, the only time you would need the dvi is for a higher quality of picture. if you do not need the higher quality (ex. you don't watch hd movies, you don't play games with awesome quality gfx, you don't do professional gfx.) you only need the standard vga (the one your used to). [note: you might need to upgrade your video card to use the dvi cable]
Posted on May 10, 2008
I have a AL 1715 Monitor that takes forever (sometimes Hours) to appear . Power Light comes on but just flashes Green. Bought new power cord and video cable but still have the same problem. Dont have...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
May 22, 2011 | Computers & Internet
Monitor will not stay on
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 12, 2011 | HP f2105 21" LCD Monitor
I bought a mag innovision model 780 monitor at a garage sale to use with my ACER mini laptop. This monitor has a manufacture date of January 2003 - it did not come with a power supply. Where is the power...
With Most Mag monitors, the plug is a simple 3 prong on the bottom side of the monitor. Though it isn't proprietary, it isn't a common power plug either. Radio Shack does carry this type of cord. Just look on the bottom side of the monitor itself. the three round plug "thingy" is where the 110v plugs in straight from the wall. Best of Luck!
Feb 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Do not know what plug ins to attach to computer I have power to the screen and it is on screen saver. I do not know what screen cords and attachments to use? None of the usual printer cords fit the back of...
It's very likely what you call the flat plug is the video cable. (Picture #1) below. The corresponding cable looks like (Picture #2). The other cable (A/C) by elimination plugs into an electrical outlet. Are you seeing a cable other then this one coming out of the back of monitor? d82bfa4.jpg697a779.jpg
Nov 29, 2009 | Mitsubishi Diamond Pro 91TXM 21" CRT...
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
Acer x213W - setting the resolution
Sorry about the delay. I also just purchased an Acer x213w and had some trouble setting up my computer in order to achieve the optimum resolution of 1680x1050.
I'm using an HP Pavilion m7170n, so it's a bit old and thus could not support this widescreen resolution. However, my computer comes with an ATI Radeon graphics card and, upon contacting HP Support, was allowed to download ATI's "Catalyst Control Centre". After installation, these drivers added the option of selecting a screen resolution of 1680x1050 from Desktop properties.
So this is my solution to you: simply google your graphics card along with 1680x1050 driver and hopefully you'll be able to download a driver update which does the same for you as it did for me.
May 11, 2008 | Computers & Internet
ASTVision 20P 21 in.CRT Conventional Monitor?
the power cord can be purchased anywhere as it is standard 3 wire block connector.
radio shack , computer store, goodwill, garage sells,
tv stores,
Feb 04, 2008 | ASTVision 20P 21 in.CRT Conventional...
I bought a balance monitor
I have this monitor currently and I ordered another one off ebay and I am also in search of another power supply for the one that I purchased. Since I alredy have one I know that the one that works with my current monitor is manufactured by a company in china called Linearty Electronics and this link: http://www.linearity.com.tw/EPmenu_LAD6019.html is to a spread sheet that list the model that was packaged with the 19" Balance Monitor. (or at least the one that came with my monitor). The model # for the power supply is LAD6019AC3 it's 15v DC 4A. The website gives no information about how to order it via them but they have a contact page that gives a sales email addy as well as hr and gen inquiries. I have sent an email today to see if they can direct me in the right direction to get a power supply for this monitor. Hint: If you got to the site you will have to change the language to english on the main page of the site since this company is a chinese company their site will automaticy come up in chinese except for the word english that the top that will convert the site to english. I will post another response if I hear back. I sent the email just a few minutes ago.
Oct 17, 2007 | Balance CM2019 19" LCD Monitor
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
