Question about Home
Hi, when i flush the water it sometimes works good and flush the dearty filling a clean water insted and sometimes just fill water without flushing the deart (or partialy flushing it). It happand random' sometimes it work and sometimes not/ pls help tks
  • 28 Answers
Not exactly sure what you are saying but have you checked the flapper inside the tank? Mayneed to replace the flapper or the flush vale unit.
Posted on Sep 02, 2010
HOW TO FLUSH AND RENEW COOLANT?
if the thermostat is in the head at the top radiator hose , remove it an fill the cooling system until the water is at that point --refit the thermostat and continue filling
make sure that the heater is turned on so that any air is moved out of the system
May 30, 2016 | Cars & Trucks
How to flush a radiator in a 1998 ford expedition
Depends whether a problem is suspected or whether the radiator is definitely the cause of the trouble.
Flushing a radiator requires it to be no worse than moderately blocked because without reasonable water flow flushing is doomed to failure and even then it is nearly impossible to clean the interior of a radiator without taking it apart and rodding out the tubes or using either an acidic or a caustic additive.
Flushing the old coolant out and a small percentage of sludge is as much as can be accomplished unless an additive is used and even then with variable success. I do this by disconnecting the heater outlet hose and fitting the (turned on) garden hose to it and then running the engine until the water runs clear. Once this is done I transfer the garden hose to the top of the radiator (top hose disconnected and plugged) and also plug the disconnected heater hose. Start the engine and run until the water runs clear from the heater outlet.
A more thorough cleaning will require the radiator to be removed and laid flat on the floor. This is definitely a kill or cure process but no less risky than using a caustic additive.. The results are usually quite impressive but beware - you and anyone nearby is likely to get wet.
I have the poor-man's pressure washer, officially entitled a water-air gun, but as long as the radiator is filled with water and water is running through it and the inlet is sealed apart from the water-air gun or other arrangement that allows compressed air to be introduced into the filled radiator while water continues to flow will have the desired effect. I kneel on the radiator to keep it stable and sometimes I feel it grow under me when I give it the full air tank pressure.
If it breaks, the reason is it wasn't much good in the first place...
May 08, 2016 | Ford Cars & Trucks
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
After each flush, the tank fills but the fill valve doesn't stop and the water keeps running into the toilet. How could I adjust the fill valve?
Usually the problem is dirt in the fill valve and not an adjustment problem...
depending on which valve you have it can be taken apart and cleaned out... just remember to turn off the water supply before taking the fill valve apart...
Jul 28, 2010 | Kohler Toilet - One Piece with Ingenium...
Toilet when flushed makes a large bubble surface from the hole. Sometimes the toilet will not flush away a bit of tissue.... very frustrating..
Have you checked it out for any blockage in the toilet or drain line.
You could try a 6ft auger to try to remove blockage from toilet.
If it is a drain issue it is either blocked somewhere or the vent is not working correctly causing it to get air bubbles.
Check you tank for proper water fill level up to marked line. Also make sure fill line from fill valve is connected to overflow pipe to fill bowl up correctly.
Not enough water in tank will affect the flush.
Jun 11, 2010 | Home
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
I BELIEVE IAM HAVING SOME TYPE OF VACUME ISSUE WITH TOILET
The water in the tank is not filling to the water line, thereby not providing enough water to flush properly. Adjust the float so that the tank fills to the water line
Apr 27, 2009 | American Standard Colony 2388.012.222...
Washer will not turn on
You have some scale or something keeping the water fill valve open most likely. If it still tries to fill unplug the machine if it still tries to fill do the following. Remove the fill valve and disassemble it. If you see the dirt or rust flush it out when it looks clean reassemble it and before you attach the hoses put them in the washer and turn them on to flush out the lines then reattach hoses and try it.
If this helps you please rate me with as high a retign as possible. If not please restate your problem and help me understand better what trouble your having. Thnks for using fixya and good luck.
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Home Logo
52 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
