Question about Fedders X Chassis A6X05F2B Air Conditioner
I need to change the selector switch in my Fedders window AC but I'm not sure which wires go where. Is there someplace I can look at a diagram that shows how to do this?
3 Suggested Answers
jj505
  • 195 Answers
SOURCE: Need wireing diagram
Might try Manual @
http://www.appliancefactoryparts.com/dehumidifiers/helpcenter/ownersmanuals/fedders/
Posted on Mar 16, 2009
  • 1796 Answers
SOURCE: have a kenmore coldspot window
Click on the following link to see an owners manual for a Carrier Window AC.
If what you need is only the electrical diagram, the one in this unit is basically the same as the Kenmore.
http://www.managemylife.com/mmh/owner_manuals/11722/CARRIER-Air-Conditioner-Room-(42)-L0603053?brand_name_search=Air+conditioner++room+%2842%29
Keep me posted!
Posted on Aug 21, 2010
I got my craftmade ceiling fan about 10 years ago, the fan has now stopped working but the light works, I changed out the switch on the wall that was not the problem sometimes I will turn on the wall...
pretty sure its the 3 speed pull chain switch.$4.50 to $6.00 at home depot or lowes or hardware/elecrtical store.
how 2 replace switch.
1.turn off breaker to fan/fan lights,probably that whole room.
may need extension cord & floor lamp from closest room with electric, so u can see.
2.need 6ft step ladder to get up to fan.look see how to get to fan speed switch. speed switch unscrews from outside but body of switch is inside fan cover.
3. need to take fan off ceiling to replace switch.
4.switch has 4 wires, power feed into switch and 3 selector
wires that go to high speed winding,medium speed winding and low speed winding.
speed selector switch has 4 settings, off, low,medium,high.
about ac circuits , black wire is 120 volts, hot.
white wires are neutral return wire. an ac voltmeter will read 120volts ac with its red and black probes between black,hot and
white,neutral.
white= neutal=ground which is green. If wired properly and polarity was observed, white and green ground wires both connect to the neutral ground buss bar in the circuit breaker panel box and are the same electrical point.
black wires,and the selector handle getting the hot juice into the fan and white returns the used juice to the circuit breaker panel box.
If polarity was observed, you can touch white and ground without getting a shock.
black will jolt or even fry you dead, so make sure the breaker to the fan is off, so that the circuit is de-energized before you touch it.
PLEASE NOTE--- make drawing on paper of what color wires from the fan motor go to what color wires on the selector switch.
If the switch has 4 black wires, you need to put different color electrical tape as a marker, on each wire. or ,to be cheap, you can use white paper,scissors to cut paper,and pencil and write 1,2,3,4 on the paper and tape to the 4 switch wires.
that is: wire # 1 from the switch goes to the black wire from the wall--ac hot
wire #2 from switch goes to yellow fan motor winding,
wire # 3 from switch goes to orange wire from fan motor
wires are specific and NOT interchangeable.
go to www.ehow.com & type into search engine box
how to replace fan motor speed selector switch.
Oct 12, 2013 | Craftmade International CQ52 Ceiling Fan
I need a fuse panel layout diagram for my 2001 mazda b3000 pickup
I purchase atruck and they put a wire from the compressor ac to fuse box. I want to eliminate that because ac compressor is always on. I check the ac heater selector switch and is ok. What if they take the fuse of ac out and bypass with a wire. Wich number in the chart fuse box is the compressor switch
Mar 13, 2012 | Cars & Trucks
Fedders air conditioning model a3t12f2ag , my unit runs fine but it will not blow cool air?
you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
Jun 18, 2010 | Fedders A6D24E7D Wall/Window Air...
1997 f-150 will not turn on ac compressor or activate heater door acctuator no power to potentiomometer switch either. Have no power to ac cutoff switch or pressure cycling switch, have changed...
It sounds like something that happened to mine, I just left it, and it corrected itself a few days later. you've probably got moisture in the electronics.
Oct 14, 2009 | 1997 Ford F150 Regular Cab
My Fedders plug in AC will not start. Is there a reset button? The model # is A6X05F2B
Hi, yes right on you plug, if not, make sure there's voltage in receptacle, check your plug for any damages, your fan should be blowing, it seems to me you have no power in receptacle, check house panel for trip breakers, or you will have to go further, by removing front cover, with power off, and check master switch, sometimes master switch goes bad, if you don't want to go further call mechanic.good luck.
Aug 04, 2009 | Fedders AED24E7F Wall/Window Air...
Can some post the 1999 gmc sierra wiring diagram
you don't have enough pressure in your system. odds are you have a leak someplace and the factory installed a saftey switch to keep the ac from running when there is no pressure. This way you don't end up burning up your compressor.
Jun 28, 2009 | 1999 GMC Sierra
Fedders Window AC
You may have thermostat problems. If the blower and compresssor kicks on, that indicates their ok. If you have a two wire thermostat, you can tie those wires together to see if the unit will operate. BE SURE TO DISCONNECT POWER.
Aug 16, 2007 | Fedders X Chassis A6X08F2A Air Conditioner
Fedders X Chassis A6X05F2B Air Conditioner Logo
74 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Tony Pez
Level 1 Expert
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
