Question about Kenmore Oasis HE 27082 Top Load Washer
F-51 code - Kenmore Oasis HE 27082 Top Load Washer
  • 2,272 Answers
Motor RPS Failure--F then 51 flashes when there is a motor rotor position sensor(RPS) senses rotation after stop command.F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT.But if that does not help then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 01, 2010
What repairs should be made for diagnostic codes 13 and 51 .
which engine, that be first. no? look at it and what is it?
ill pretend 4.0L I-6
old car, with OBD1. code 13 and 51 are fully covered in the FSM.
ever seen and fsm? login to aldata.com and read.
and is discussed , infinitely on all jeep forums on the net. endless.
google that.? yet?
here ill google for you
i google jeep 13
http://www.allpar.com/fix/codes/faults/code13.html
and jeep dtc 51
http://www.allpar.com/fix/codes/faults/code-51-52.html
13 would cause 51s so,...... work that.
Oct 02, 2014 | 1994 Jeep Grand Cherokee
What codes are these to 1994 geo panel blinks two numbers 42 and 51
Ignition bypass error.42,incorrect MEM-CAL 52.
Aug 24, 2014 | Cars & Trucks
My problem is malfunction code 51 and if I have bad convertor does this result code 51ode
Code 51 is a lean code and is not caused by a converter most likely a vacuum leak is causing this problem if the engine seems to run fine inspect vacuum hoses and intake gaskets for leaks or breakage
Dec 10, 2012 | 1997 Jeep Grand Cherokee
Need tofind out code 51 for 1997 jeep grand cherokee 4x4
Code 51 is ( Right Rear Fuel System Lean ) A lean air/fuel mixture has been indicated by an abnormally rich correction factor. Did you get this code by the flashing check engine light?
Sep 04, 2010 | 1997 Jeep Grand Cherokee
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Code 51 for chevy van g20 1990
code 51
oxygen sensor voltage indicates lean engine operation
this code lights up check ingine light on vehicals with special california emission controls
Aug 21, 2010 | Chevrolet G20 Cars & Trucks
I have code 51 flashing. Where is the air bag diagnostic module located?
Hi, the code 51 flashing means that the internal fuse is blown and the short to ground is no longer present. If the short to ground returns, the code will change to 13 (air back circuit shorted to ground) or 14 (primary crash sensor circuit shorted to ground), but it will only flash 13 or 14 when the short is present. If the code remains 51, then first find and repair short before replacing the diagnostic monitor (what people call air bag module).
Take care
Aug 03, 2010 | 1994 Mercury Grand Marquis
Car problem
51= O2 sensor lean,
55= end of codes list
Jan 29, 2010 | 1991 Chrysler LeBaron
Hi, I get code number 51. Not sure what I can do to find and fix problem. Thanks
Code 51 is Wide Open Throttle Problem. You need to replace your fuel filter, possibly drain fuel tank and clean fuel pump pre-filter. That is in the fuel tank. If you have the cash, I would replace fuel pump while inside the tank.
Sep 25, 2009 | 1994 Chrysler LeBaron
Kenmore Oasis HE 27082 Top Load Washer Logo
172 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
