Cds won't play
When I press play the cd is spinning but won't play; tried using a cleaning cd and it didn't help. Looks like it is spinning very fast.
  • 3 more comments
  • johndoyl3r Jul 17, 2008
    cds keep saying error when i put them in and starts spinning really fast and makes loud sounds.they used to work properly but after a while they started giving trouble.
  • Anonymous Dec 12, 2008
    I have the same problem and i tried using a cd disck cleaner and still not working
  • naperoak Dec 23, 2008
    I have the same issue. CD's don't spin fast however. Just get the error message after it tries, for a while, to play a CD.
  • Anonymous Feb 02, 2009
    cd wont play
  • rjackson417 Feb 22, 2009
    cd won't play
When i put in the cd it always said error
Posted on May 11, 2008
My cd part of aiwacd3 wont play any longer. i looked through the top window and it appears that the disk does not fit centrally under the playing head sometim and then the head spins a few revolutions,...
hi there.
Although CDs are still the preferred method of audio distribution, CD players are quickly being phased out in lieu of MP3 players. If your old CD player stops working, it might be a little panic-inducing, but fear not. If the CD player turns on but does not play CDs, then the problem is not with the power cord or the circuity (which are generally more expensive to repair rather than fix) but with the lens. There are several troubleshooting steps that you can take to fix a CD player when it won't play.
Step 1 Remove excess dust from the CD player. Dust is the number one enemy of electronics, and it can corrode even the most resilient device. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
Step 2 Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Step 3 Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
if you need more info go to this link.
cd won play Google Search
Dec 11, 2017 | Audio Players & Recorders
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
Mar 14, 2013 | Audio Players & Recorders
CDs won't play
The problem is in the laser pickup assembly, try cleaning the laser lens with a Q-Tip and rubbing alcohol gently, allow several minutes to dry, if this fails the whole assembly must be replaced, not cost effective to repair cheaper to buy.
May 09, 2012 | Sony boom box micro midi mini-fi systems...
It won't read that there is a disk in the drive. When I put the disk in it makes a lot of noise and sounds like it's trying to start but in the end it quits and doesn't do anything.
If this happens even if you try to play several cds, then lens inside which reads the CDs needs cleaning. Try using a CD cleaner and let that spin inside the cdrom for like 30 seconds. Then try playing the a cd again. If it still fails to read them, you may need to manually clean the lens inside. Open the casing and unscrew the plastic plate the covers the lens. Get a q tip or a cotton bud and damp it with alcohol. Gently wipe the lens' surface and let it dry. Then return evrything back and try playing those discs again.
Hope this helps.
Oct 30, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Having trouble getting CDs to play
clean the lense that senses the CD. had same problem, cleaned with damp tissue, problem solved
May 04, 2009 | Bose Wave Music System CD Shelf System
I cant play cds on my wharfedale pcd 6200 usb
I think you need to press and hold the Play button (marked PLAY/PAUSE) to switch between CD playback and the USB port (you can store mp3 files on a USB stick and play them directly) on the front of the device.
Try inserting a disc, switching the unit to CD mode, press and hold Play until the display changes and the CD spins up...
Might just work?!
Duncan
Mar 22, 2009 | Audio Players & Recorders
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Trutech 17 inch tv dvd player the dvd spins seems not fast enough
The first step is to clean the lens of the optics assembly (if you can get to it) carefully using a cotton swab and alcohol. If that does not resolve the problem, try playing a music CD. If the music CD plays but a DVD does not, it suggests that the laser is starting to fail and needs to be replaced. CDs require far less laser power to read than DVDs.
Hope this helps,
Dan
Dec 10, 2008 | TruTech PLV16320 Television
Cd cleaning disc is not advisable to clean your laser lens.. all you have to do is manually cleaning method! open the unit go to laser lens and clean it with 100% cotton buds then rub it slightly clockwise, but careful this is sensitive parts.
Sep 26, 2007 | Sharp XL-MP130 CD Shelf System
Error 2 on Display
Mabye. I would suggest either opening the unit up and cleaning thr "laser" (optical pickup) with a q-tip. Or try using one of those cleaning cds that have the little cleaner fabric on the inderside... if that doesent work something is most like wrong with the cd machanism wether its not spinning the cd or just not reading it due to a defective laser.. ampman!
Sep 05, 2007 | Sanyo ECD-T1550 CD Player
230 people viewed this question
 Grubhead
Grubhead
