Question about Kenmore 70088 Air Conditioner
Kenmore ac blowing black peices all over room.
When i turn my ac unit on and i run the ac. it start blowing black peices all over my stuff and when i go to pick it up it crumbles into tiny pieces and i know its coming from the black fan inside. but how do i take to unit apart and clean that fan so it doesnt blow black stuff all over my rooms?
  • 770 Answers
That is foam insulation around the seal of the evaparator box pull the unit from the wall remove the cover to get to it and clean or replace it
Posted on May 10, 2008
    New Friend:
I'm having the same problem with a Haier air conditioning with the tube from the window. I clean my air conditioner religiously, so it must be the foam disintegrating, my father even said it, as long as it doesn't kill me or make me sick, I don't care and can live with it, having a cool room is more important than little black pieces of dried up foam..
Posted on Apr 16, 2013
Unit runs well but won't turn off when tepm setting is reached
In the Remote SET the AC FAN IN AUTO MODE THE AC stops after attains the set temp.
Apr 26, 2016 | Kenmore 18,500 BTU Heat/Cool 230V Room Air...
Unit alternates cold, warm, cold, warm etc..
in high temps AC units undergo whats called thermal inversion. This is when it blows hot inside and cold outside. I do not believe there is a fix for this. Maybe it is not properly sized for you room? If your unit is too small, it may be working too hard and inverting.
Jul 30, 2014 | Kenmore 75184 Air Conditioner
2001 Dodge Ram 1500 4x4 with no heat, no ac, blows room temp air on all fan settings
The upper passenger side firewall has a little black line passing through it . Usually it is broken. There is also a ball on the drivers side firewall behind the hinge
Nov 03, 2012 | 2001 Dodge Ram 2500 Truck
My kenmore window unit AC started blowing a white smoke like substance. It seems to be cooling fine. What is this and is it a concern?
The two things it could be, #1 - evaporator leaking refrigerant - unlikely if unit is still cooling o.k. because window units do not hold a lot of refrigerant and if there is a leak bad enough to blow smoke it would have stopped cooling by now. #2 - the humidity is high and the unit has cooled the air right at the discharge down below the dewpoint, a common occurence in window units and automobiles due to the short duct distance from the evaporator to the air outlet whereas with central air systems having longer duct systems the air gains more heat before being discharged into the room.
Aug 26, 2010 | Kenmore Heating & Cooling
Turn air conditioner on, after a couple of minutes circuit breaker for room shuts off. a/c is 2 seasons old, digital ge, 12000 btu???
you have to much stuff on one circuit. turn everything off on the circuit that is blowing then try to run the ac.
May 29, 2010 | GE AJCQ08ACB Air Conditioner
What is the power draw (in watts or amps) of the Kenmore 5300BTU room air conditioner? The unit is being powered off the grid by an inverter, and I think the user chose too light weight an inverter for the...
5.8 amps. see page 9 (5300 btu is considered a 6000 BTU, 4800 is considered 5000 btu, sorta like a 2x4 ain't really a 2x4 LOL)
You cannot run an ac on an inverter, not enough juice to get it started.
May 28, 2010 | Kenmore Single Room Air Conditioner
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
Kenmore AC compressor on and off while outside unit fan running
If the out door fan keeps running and the compressor cycles off that would be the overload in the compressor.
What keeps the windings cool is the refrigerant back to the compressor.
For the overload to cycle it would have to be either not enough cooling back to the compressor or high amp draw, which could be the metering device (txv or orifice) or low on charge, or other things would be a bad capacitor, sometimes a bad start relay not staying open, when compressor gets up to speed or anything causing the compressor to draw high amps.
To check the refrigerant, he needs to check the superheat at the compressor it should be appoximately 12° to15°, and next time the compressor goes off if you shut the power off and feel the top of the compressor and if it's hot 130° or higher it's probably refrigerant.
Aug 14, 2009 | Heating & Cooling
Ice blowing out of ac unit
it is not normal either the filter is blocked or your low on charge
Aug 10, 2009 | Heating & Cooling
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
Kenmore 70088 Air Conditioner Logo
1,240 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
