I purchased a Dell 4500 used with no OS. When I registered it with Dell I asked for and received factory restore discs. The Windows XP installed successfully but I can't get online I keep getting the message no connection is found. I may not be using the application disc properly but when I select number 2 of the 6 choices to diagnose drivers it continually loops back to the six choices screen. Some work was apparently done to this computer because the skot on the back where the VGA connection should be is empty and I am using the digital connector and using my plasma as a monitor. Perhaps if I burned the NIC card driver to cd and downloaded it then I could get online Suggestions please. A little knowledge is dangerous which makes me VERY dangerous!
  • 1 more comment
  • djm5657 Sep 01, 2010
    Under network adapters it shows 1394 Network adapter which it says is working properly. Is this for LAN internet or dialup (which I don't have).
  • djm5657 Sep 02, 2010
    I downloaded driver for a netgear wn111 I burned to a disk and that immediately connected to the internet so I've been busy updating XP. A workaround to be sure but I am accepting your answer and you can view my questions tomorrow about all the yellow alerts I saw when I clicked on network connections. Thanks for your help:-D
    Very helpful and thorough. Also sent me in a direction I had not previously considered A+.
  • 11,800 Answers
First of all you need to make sure that the onboard LAN chip has been recognized and its driver installed. For that right click My Computer, Properties, Hardware, Device Manager and in there click on the plus sign next to Network adapters - your NIC should appear, double click on it to be sure it works. If it does then the problem is outside your pc - it's at your ISP : probably it has MAC filtering and your pc isn't recognized. Phone them  and they will guide you on how to register your pc in their network.
If nothing appears in Network adaptors that means that the NIC is dead. Just buy a new $10 PCI LAN card, remove the old one, put the new one in and reboot - it will be automatically detected and in 9 out of 10 cases the correct driver loaded directly by XP.
Posted on Sep 01, 2010
  • Azrael SRL Sep 01, 2010
    Neither - this is the Firewire connector , nothing to do with your network.  I.m assuming that you don't see any yellow marls in Device Manager. This means that  network card is totally dead.
    Just buy and install a new LAN card, you can find it even at WalMart in the IT section.
DELL DV051 cumputer
To restore the computer you will need to reinstall Windows from scratch with the installation media. The computer may have come with a recovery disc, this can be used to restore the computer to the point at which it was purchased.
May 22, 2013 | Microsoft Windows XP Home Edition
I was wanting to do a systems recovery on my computer. It came with XP home ed. installed. Vista has been bought and installed, and XP completely wiped as far as I can tell. I don't have the Vista or...
do you have a recovery key (f1,f2 etc) for the desktop, it flashed when you boot your desktop, press that key, it will recover your desktop to the os installed from the factory, it will be windows xp home edition
Aug 03, 2011 | Dell Computers & Internet
How to restore my Dell Optiplex 170L without losing my XP professional OS
Try CTRL + F11 when powering up.
What this does (or should do) is initialize Dell's System recovery utility. It will restore the system back to it's factory original state (the state the system was in when it left the factory). This won't remove the operating system, but if you've upgraded the OS or made significant custom changes to the computer (software wise) you may lose all the changes. If XP professional is the original OS on the system when you bought it, the recovery will leave the OS on the system. If you've upgraded to Pro, and you still have your install disc, or have access to an install disc and your XP Pro product key, you can reinstall XP Pro after the recovery.
Jan 10, 2011 | Dell OptiPlex 170L PC Desktop
I am trying to restore my inspiron b 130 in factory settings however the instructions i have are turn on computer start pushing f8 to advanced boot options then repair your computer to dell factory...
When its a computer that is using the windows XP you wont have that option .. Its a different option to restore to the factory settings
Use the following things
Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If you are not able to get into this option then there might be no restore partition availlable
In that case you have to reinstall using the disc
Dec 06, 2010 | Dell Inspiron B130 Notebook
Its not asking me to restore
best way to go about doing what you are wishing to do is to place your Windows XP disc into the computer. If your Bios is set correctly it should come up with something like "Press any key to boot from disc" of course you would press a button and the Blue Windows screen should come up and after some pre-checks it should ask what your wishing to do. From there you would format the computer, and start from scratch. Restore points inless set up, you wouldnt be able to go all the way back to the beginning when you first got the computer. Formating is the 100% sure way of getting everything off of it sept for the OS.
DrakeTech
Dec 24, 2009 | Dell Inspiron 2650 Notebook
How do i restore my dell inspiron 1501 to factory settings without the disc? i lost it and im goin nuts...
Contact Dell to purchase a Recovery CD for your model Dell laptop.
The other way is to do a new Windows install. Use a Windows installation CD, it must match the Windows version on the Windows Product Code label on the bottom of your laptop.
You will also need to download the device drivers for your model laptop from the Dell WEB support site, make sure the download the correct XP or Vista version of the drivers that match the Windows version you are installing.
Sep 07, 2009 | Dell Inspiron 1501 Notebook
FULL VERSION OF XP PRO TO DOWNLOAD ?
At the moment, the only method of getting Windows XP install media is by purchasing the disc or ordering install media directly from Microsoft. The other way is if you're a MSDN subscriber, you can usually download software images from Microsoft and use your own key.
The other way to do this is by finding a friend who has a Windows XP cd of your version [for example, Windows XP Home OEM, OEM meaning that the disc came with a manufacturer such as Dell or HP, or Windows XP Home Retail, meaning that the disc came in a Windows XP Home box someone purchased]. If you can borrow thier disc, you can use your key off of your COA [Certificate of Authenticity] which is a sticker on your computer showing your 25 digit license key. This will install Windows XP legally on your system again.
If you own an OEM computer like Compaq, HP, Dell, etc, you can also try contacting support for that PC manufacturer and seeing if you can order recovery media for your computer model. This will install the operating system, all drivers, and software that originally came with your computer back to default when you bought your PC. You may also have recovery software installed on your computer. Look under your start menu and see if you have a suite of software from your PC manufacturer, including recovery software or system restore software.
Best of luck!
Mar 16, 2009 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
