Question about Memorex MVD2022 DVD Player
Disc tray will not open and standby indicator is flashing
Hello I have a memorex mvd2022 disc tray will not open if using remote or pushing eject button, also stand by indicator is flashing??
any ideas
  • 1 more comment
  • laurenandrob Jun 04, 2008
    Having the same problem -- on/standby light is lit but tray wont open.
  • JZerbey Oct 20, 2008
    Hoping to push this back into the light...I have just encountered this same problem. Mine will not open, but seems to operate b/c I have a Hitchcock movie stuck in there and it plays with no problem.
    If I hit "open" on the remote or the player, "open(tray open?)" appears on screen and nothing happens.
    Will be using a screwdriver by Wed.
    Thank You in advance.
  • Anonymous Nov 22, 2008
    I also cannot get my tray to open and the standby light is on. It worked fine a few hours earlier!
I can't get the tray to close
Posted on Jul 04, 2008
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Tip
Remote Control Problems
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off
and the Program Button works For Sub Title other Buttons have other functions for The Memorex MVD 2022 Only thing You Have to work the sound From Surround System are TV.
on Feb 23, 2008 | Memorex MVD2022 DVD Player
Memorex burner tray on computer will not open
There should be a small hole on the right side bottom of the tray.....take a paper clip and insert it in the hole....while pushing the eject button...it should open then.....let me know if i helped you.
Mar 24, 2012 | Memorex MVD2022 DVD Player
Disc tray does not open
When you press the eject button you should hear the loading motor engage trying to open the dvd door, if you hear the motor! it indicates a bad loading belt that is stretched or direct drive gear problem, either way dis-assembly will be required to take a shot at repair.
Jan 01, 2011 | Memorex MVD2022 DVD Player
Will not open door to insert DVD. What can I try?
remove the top cover and look at the side of the tray.there is a small motor and belt that drives the tray.the belt is probably pear shaped from sitting so long. give it a gentle push and it will probably open.some are gear driven and the motor could have a flat spot.in any event,push the tray gently and it will most likely open.
Apr 13, 2010 | Memorex MVD2022 DVD Player
Memorex mvd2022 dvd player froze, nothing works
we want so many things to repair it.so the better way is to go to a servicing center
Jul 19, 2009 | Memorex MVD2022 DVD Player
Flashing power light
my problem is I want my laptop atualisar has 32mb Hasan xp and I want a CD and I can not put a program she is more modern windows 98 am programs and not the camera is not compatible for grabs if I can help as atualisar thanks
Jul 28, 2008 | Memorex MVD2022 DVD Player
Mine looks like it might have a burnt 5W33K resistor. It's the large resistor labeled 5W33KJ located on the front right corner of the main circuit board.
Jan 25, 2008 | Memorex MVD2022 DVD Player
Memorex MVD2022 DVD Player Logo
313 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
