I have a whirl pool duet get loader washer n codef22 .is on.what does that mean.
  • 2,272 Answers
Whirlpool Duet Front Loading washing machines displaying the "F22" error code.
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 01, 2010
Whirl pool duet sport the door is locked and it wont let me open it
You can remove the lower panel. Have to drain the hose - water rushes out...and then reach up insie the washer where the door latch is, there will be a ring that you can pull on that releases the lock.. Got that much done...but the beeping continues... Be sure to unplug the machine first!
Nov 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an error of f 35 and can't find any information on problem? whirl pool front loader
hello,
what this sign indicate is an error code meaning that there is over flow of water around the panel connected to the lens reader,
what you will have to do to fix up the f35 code problem on the screen of your washer is to unscrew (open) the washer with stroll driver with care then trace the wire(power supply) down to the panel and the screen then clean up all for of liquid or water around them with care with out disconnection of wire .please note this information do not use any form of liquid to d the cleaning then make sure that power supply is disconnected from the washer before working on it then couple it back as it was
Rate this if it help
thank you and thanks for using fixya.
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool duet washer, will not drain error code f 02. When drai hose is lower to floor water comes out slow
F02 means long drain time exceeded 8 minutes. The problem is most likely a clogged Filter screen. Remove lower front panel you will see a white filter before the pump assembly. Place a towel or a tray under the filter assembly. Open the filter and remove any blockage from the filter. The other could be a kinked hose but it is usually a blocked filter.
Nov 01, 2009 | Whirlpool Washing Machines
No power
The following link explains how to replace the drain pump on a Whirlpool Duet:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fo2 on screen
your pump is jammed clean or, replace
Aug 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer does not go past wet cycle
if your vent hose is clogged, your element most likely burnt open
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool duet
Lets run a diagnostic test selecting drain/spin, on spin speed select no spin then press prewash quickly twice, watch for F error codes and write them down, press prewash again to advance past error code seen. Then post back because there are several issues here that can cause this, motor sensor errors, serial communication errors, pump and drain siphon issues.
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
