Question about iRiver PMC-120 Digital Media Player
WIndows Vista I was goin to buy the iriver pmc 120 digital media center but wanted to know does it work with wmp 11 and windows vista
Yer it works
Posted on Sep 04, 2008
My laptop does the "found new hardware, mtp device" popup, but doesn't recognize it as iRiver
Here's the link for the user manual if you need it; check page 137 of the pdf and try the restore to original settings. do you have the setup cd? - it has troubleshooting for the unit, which is not available on the website there are no drivers available, it uses windows media player as a driver, but the manual and the support site; both claim that you need windows media player 10, not 11 to synchronise. you can download it from this link; or install it from the setup cd just uninstall wmp11 first. many of this type of unit and mp3 players etc have problems with wmp 11, hopefully reverting to 10 will allow you to sync Hope this helps :)
Jun 27, 2007 | iRiver PMC-120 Digital Media Player
VISTA's Windows MEdia won't regonize my player.
can i sway you away from wmp (your os is vista) .... its very good for iriver h320 too...
May 23, 2009 | iRiver H320 MP3 Player
Windows Media Player incompatible with my Iriver U10
download the latest wmp 11
it would work just fine
Mar 09, 2009 | iRiver U10 Digital Media Player
I need a replacement lcd screen for my iRiver PMC-120.
i got a lcd i can sell u for 50.00 email me
Feb 10, 2009 | iRiver PMC-120 Digital Media Player
I river x20
Screw Window Media Player. Just use the included software instead. Iriver Plus 3 makes all the necessary conversions for your player, to make sure it works properly. WMP messes stuff up a lot.
Apr 26, 2008 | iRiver X20 MP3 Player
How can i get this iriver pmc-120(20GB)Digital media player
Ebay have them at around $300-350 +p&p.
Hope this helps,
Mar 15, 2008 | Televison & Video
Need a driver for the pmc 120 for XP.....
You need to use windows media converter (under the windows media folder) and convert all videos to WMV format and you have to use 320X240 output resolution, 800kbps sound quality. Anything else will result in a format out of specification error. Now where to move those video files is a mystery as there is no video folder. You can move all pictures into the pic library, etc. Windows Media Player 10 is designed to natively pick this device up and make synchronizing easy. when I plugged my Ebay PMC-120 in, Windows media player tried to sync all media files to my device, pictures, music, windows sound effects, etc. Should not be an big deal if you have the correct USB cable, mine came with one. has the software, but you have to go into the update software area of the site and there is a link to the master program in a set of upgrade instructions, no other place that I looked. Not Vista compatible unless you download the installation program and set its compatability to winXP BEFORE you run it. And stick with WMP 10 as it was around when this device was made.
Nov 19, 2007 | iRiver PMC-120 Digital Media Player
My iriver pmc won't switch off
make sure the hold button on the bottom is showing white, not red (locked) if that doesn't work, just pop the battery off and put it back in.
Aug 26, 2007 | iRiver PMC-120 Digital Media Player
Casing replacement
I have one with a broken screen i can sell you.
Jan 29, 2007 | iRiver PMC-120 Digital Media Player
Open Questions:
pmc 120 when i set up a sync list on media player and start to sync it to the pmc, it works sometimes, other times it aborts. it gives me the message "you can now disconnect iriver Portable media centre" when i try to do it again it tell me Windows Media Player encountered a problem while synchronizing the file to the device. For additional assistance, click Web Help. when i go to th web help it explains the problem as You've encountered error message C00D1236 while using Windows Media Player. The following information might help you troubleshoot the issue. Cannot sync the file Windows Media Player encountered a problem while synchronizing the file to the portable device. Because this error can occur for a variety of reasons, there is no single solution. To resolve the problem, try disconnecting and resetting the device. See your device owner's manual for specific instructions on performing this procedure. In some cases, this error can occur if you try to sync a hidden file to a device. To resolve this problem, either remove the file from the sync list or change the file's properties so that the file is not hidden. Also the error details are Technical Details This error might have been triggered by an error in another program or component of Windows. The following information describes the original error. Original Error Code Original Error Message C00D1179Windows Media Player does not detect a portable device. Connect your portable device, and then try again. So im not sure why it keeps aborting. if you can tell me your views on this please do. Other information that may be useful i tried formatting the unit : 1. Through windows media player 2. through explorer the pmc is supposed to be used with windows media player 10. i had wmp 11 originally and it didnt really work too well. i rolled back to 10 and it worked better but still not consistantly. i tried installing wmp11 again and now the Pmc120 will abort after about 3 songs of an album i would have setup to sync. thanks for your help. Gavan Doran. Ireland.
Oct 16, 2007 | iRiver PMC-120 Digital Media Player
iRiver PMC-120 Digital Media Player Logo
178 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
