Question about LG 32LG30 32 in. LCD HDTV
We have a wall-mounted LG 32" TV, which was working fine. Yesterday we turned it on, and while the power is responsive, there is no image on the screen - no menu, no option for changing input - nothing whatsoever. Any ideas why this may have happened or how it can be remedied?
    Scholar:
  • 120 Answers
The basic reset, Unplug from power for 30 sec. plug back in. If still not resolved a component board in the TV has failed and the TV will need internal parts serviced or replaced. The power boards on this model are known to have capacitors that fail, If you see no light behind the screen this is most likely the problem but there is know way to tell with out taking the tv apart and testing.
Repair cost should be under 200 My be better to buy new with warranty
Posted on Sep 01, 2010
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
Can I use any universal wall mount for my LG
Just check the weight and size restriction on the wall mount. As long as the weight and size specs of the TV fall within those allotted by the wall mount, you should be fine.
Nov 13, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Blank Screen
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I have sound but no picture on my 32 inch LCDHD TV/DVD. Picture flashes for a second an then the screen goes blank. Thanks Bill
This problem is caused by one of thee problems.
1) The inverter board(s) is bad.
2) Power to the inverter board(s) is off.
3) The CCFT(cold cathode fluoresent light) is bad.
Since the picture flashes for a second you may also check for loose connections for the above items.
Here is a simple test you may also try. With the TV on take a bright flashlight and press it against the screen. Look for an image around the edge of the flashlight. This will verify that an image is being sent to the screen.
Mar 12, 2009 | Televison & Video
SOUND BUT NO PICTURE
I had the same problem today with the same symptoms. I tried a power reset, removing the cables, checked all inputs and got the same symptoms.
I found a temporary fix. When I turned the TV on, I immediately press the backlight but on the remote until the bar appears then lower the setting down to 10. This may take a couple of tries of powering the TV off/on. Once I got the setting lowered to 10, the picture stayed on. If you invoke any of the presets it will change this setting. I'm going to call someone and try to get more information on a permanent fix.
I hope this helps, at least I got the picture back.
Jan 27, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Lg lcd tv screen goes black but the sound still works 52lg70 screen goes blank, sound still works. i can change settings but cannot see the menu so the tv is still working there is just no picture.
This sounds like a mainboard problem. Unless you do not see a back light flash when you turn on the TV, which may mean it is an inverter board problem, this is most likely fixable by replacing the mainboard.
Jan 20, 2009 | LG 52LG70 52 in. LCD HDTV
Screen goes blank, audio still works
Oct 26, 2008 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
We just set up our 37 in sharp and get no picture
If this is a new set, return it for an exchange. This one sounds like an LCD set which uses a "back light". This back light is not working. This is a warranty repair or exchange.
Dan
Mar 17, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Panasonic Quintrex 32" 100Hz CRT
Use an uninterrupted power supply, UPS.
Feb 21, 2008 | Panasonic CT-32SL15 32" TV
LG 32LG30 32 in. LCD HDTV Logo
57 people viewed this question
