Question about Dell Dimension 8300 PC Desktop
I'm trying to find out if the whole front panel power switch on the dell dimension 8300 can be replaced with a generic brand . I have changed the motherboard, replacing it with a SIS 648FX Foxconn board. My problem is finding an appropriate front panel switch, or a way to get the present dell setup work. Any suggestion would be most helpful Thank you
  • 245 Answers
The problem you're running into is that Dell uses proprietary parts,like quite a few manufacturers still do.The board you bought should have come with a manual on a CD or DVD.You can look through the manual and see what the connections are,they're even printed,usually,on the board beside each set of pins.It's very small print.
What you have going for you is that the Dell multi-plug is also labeled as to what wires are for each application.You'll have to cut the plug off and put individual connectors on each wire,then connect them to the corresponding pins.You can get the parts at an electronic supply store,even Radio Shack.
Just be careful,and make sure that if your hands are inside the case,the cord is unplugged.
Bob
Posted on Sep 01, 2010
I have Dell PC Dimension 8300. Yesterday I have turned off computer and now I cannot reboot it back. It starts and then it stop and on screen is: strike F1 to retry boot, F2 for setup utility and cursor....
go to F2 and check the time and date if this is wrong you may need to change the COSMOS battery take off the side panel you will see a large watch type battery it is sprung loaded just replace it.
or insert your operating system disks follow the on screen prompts.
Oct 07, 2010 | Dell Dimension 8300 PC Desktop
I HAVE CHANGED SO MANY POWER SUPPLIES IN MY COMPUTER THINKING THAT IT WOULD STOP MAKING NOISE BUT ALL HAS NOT WORKED AT ALL. (THE FAN OF THE PROCESSOR DOSE NOT MAKE ANY NOISE)IT IS DELL DIMENSION 8300....
is your fan brand new? you can remove cover of that power supply and take out that fan put some lubricant like f2 oil. that brand i use to lubricant on scanner and printer and in fan also.
Apr 08, 2010 | Dell Dimension 8300 PC Desktop
How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
May 14, 2009 | Dell Dimension 8300 PC Desktop
Will not start
That's just about the opposite of what most systems would like. The colder they are, the better they run. There's a good chance your power supply is dying. Also, check and make sure the vents are not clogged with dust.
Dec 21, 2008 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Power button mulfunction?
Most front covers have screws that hold them to the chassis. Unscrew the screws and be careful not to break any wire connections to your front panel. Then you'll be able to examine the power switch.
Sep 22, 2007 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 PC Desktop Logo
132 people viewed this question
Alun Cox
