Question about Samsung LN46A630 LCD TV
There is a 4" to 5" column of lines running down the right hand side of the screen. When you first turn the tv on the lines are different colors and they run straight up and down. After the set warms up, they become more like static...the easiest way I know to explain it is...on the old type tv...it looks like the picture is rolling. It remains the same no matter what the source is...ie. cable box, ant., blu ray player. Any ideas...or is it going to cost more to fix than its worth?
  • 10 more comments
  • dtucker3usa Sep 01, 2010
    Thanks, I appreciate it...is this something that I could replace myself?
    I don't know if you got my last post...is this something that I can replace myself...the 2 boards look totally different...so that shouldn,t be a problem.
    I have a lot of experience with computers...desk tops
    What is the safest way to remove the 2 paper connectors from the lcd display?
  • dtucker3usa Sep 25, 2010
    T-Con Board didn't fix the problem...I'm trying to post a picture of the screen so that you can actually see what the problem is.
    Do you have an e-mail address that I can send them to you...I can't seem to get the pictures to copy and paste on this site.
    any suggestions on how to get the pictures to up-load to this site?
    you should get the pictures now...Let me know if you can see them well enough.
    this time i used nicon coolpix camera...i hope they are better quality
    Can you see them ok this time?
    Thanks Jee...is it going to bbe worth replacing the lcd screen or should I just get another tv?
    Thanks for all your help.
  • 10,594 Answers
It sounds bad lcd panel in your Samsung LN46A630 and if tv is under warranty, please call Samsung or Store for warranty cover.
If tv is out of warranty then T-Con board replacement might solve tv issue.
There are two type of t-con boards used in this tv and local tv repairman will confirm what type of t0con board is required, T-Con-1 and T-Con-2 are available with Shop Jimmy
Again, I would say, it seems bad lcd panel and t-con board replacement might fix the issue. (t-con board is part of lcd panel but few spare parts shop sell it separately)
Hope these info will help you.
Thanks.
Posted on Sep 01, 2010
  • 6 more comments
  • Shahid Electronics
    Shahid Electronics Sep 01, 2010
    It depends on your expertise, t-con board is located at top center of lcd panel if you see its rear side and will be covered under metal shield.
    Two flexible ribbon wires are hooked in long flat connectors of t-con board that are coming from lcd panel, these are fragile, delicate ribbon wires and must be handle carefully.
    Click on above links to see t-con board images and find out which one is mounted in your tv to get same replacement.
    Thanks.
    OK, below image will help you to locate t-con board.
    Not from lcd display, 2 flexible ribbon wires will be removed from t-con board connectors, unlock the connector by lifting up bar on connector and slide out ribbon wire.
    Shahid Electronics Sep 25, 2010
    OK, if t-con board replacement did not solved the problem then it is bad lcd panel as it was explained before.
    I would like to see picture of screen.
    welcomejee@yahoo.com
    Send pictures at that address
    I got pictures but file size is too small like thumbnail image.
    Email me full size picture taken by good digital camera because I have to enlarge it to determine the lines
    Yes, pictures are fine this time.
    It is lcd panel problem and complete lcd panel (screen) will be replaced.
    New lcd panel would cost you approx 80% of new tv price and would be available only with Samsung service center, now you can decide better, either get it repair or buy new one.
    Thanks.
What's wrong when I turn my tv on I have sound but no picture. My screen isn't black. It's white with different color lines running up and down the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "Line fault" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 19, 2016 | Sharp Aquos Televison & Video
Line down the center of tv screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 04, 2015 | Samsung Televison & Video
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Mar 24, 2012 | LG 37LE5300 LED TV
I have a 47 inch sanyo lcd tv and the screen is broken in the lower right hand corner i want to know how much it will cost to fix and i dont want it will be cheaper to buy a new one
i have a 47" inch lcd sanyo t.v. and my kids accidentally shot it with an air-soft gun. and there is a crack where the pellet hit and there is also a crack running down that spot. Also the screen has these lines running up and down the screen. Different colors. and i was wondering if it was possible to fix.
Jun 02, 2010 | Sanyo DP32746 32 in. LCD Television
I have a Samsung 42" plasma Model HP-R4252 TV and now I see a group of blue/purple vertical lines on the right side of the screen from top to bottom. Each one is about 1mm in width but all together they...
You may have to change the DMD (Digital Micromirror Device). Also you may have to change the color wheel and lamp; the DMD will cost you around $200-$300. The color wheel and lamp will together cost you another $300.
This type of tv repair may be very expensive especially if you have to pay a technician to perform the repair for you.
It's at that point that you may decide to invest in a new unit.
Oct 13, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Screen problem
bad panel if it's cracked
Apr 27, 2008 | Vizio L32 32 in. LCD HDTV
Samsung LN46A630 LCD TV Logo
312 people viewed this question
Jerry Greenberg
Jerry Greenberg
