Question about Intermatic EI220 Electronic Auto Shutoff Timers
My intermatic E10694 timer will not shut off the pool now. You can move the lever and it clicks and the diodes that on the dial that make it turn off and on hit the appropriate part on the switch. It is just time for a new one?
  • 30 Answers
SOURCE: Changing Pool Timer
As long as you get a new timer that is 220/240v and is the same amperage or larger, you should be fine. Wiring would be the same.
Posted on Jul 09, 2009
rockitman187
  • 2559 Answers
SOURCE: How To Program An Intermatic PE15300 Pool Timer ?
1. Press PROG Key to cycle through menu options.
2. Press UP and DOWN arrow keys to change program settings.
3. Press ENTER key to save changes and exit programming mode.
4. Press ON/OFF keys to manually turn devices ON or OFF.
Please post back if additional info is needed
Please take time to rate this fixya
Posted on May 13, 2009
jmgldsmth
  • 2005 Answers
SOURCE: pool timer not turning pump on
the timer motor brushes are worn out
Posted on May 28, 2009
protek480
  • 1723 Answers
SOURCE: Intermatic pool pump timer, time clock won't turn
Check your wiring, it sounds like it's not right. The clock needs 120 volts to run.
Posted on Jun 30, 2009
  • 112 Answers
SOURCE: Describe your Intermatic
is the dial turning, or is it in the set mode, were its not engaged. if it does turn are the trippers tripping the levers. if everything is working make sure the trippers are not bent, this will keep it from engaging anything.
Posted on Aug 22, 2009
What position is lever on intermatic pool timer t104p3 for timer to work?
Lever automatically moves back and forth as trippers pass.
Move lever to ON position, move to the right.
If timer dial is not rotating, then check wiring, or replace clock motor:
If timer worked before and stopped working, but dial still rotates, the trippers are worn down, replace trippers:
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Buy-T100-series-timers.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Gene
h
May 20, 2014 | RTO Intermatic Inc Ej351c Timer Night...
E10694 timer
Scroll down and identify timer:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
E10694 is imaginary number applied to all sorts of intermatic timers sold by folks who want their timer to appear unique and rare on internet. It has been used for T101 120V timer, T104 240v timer, T170 series timer with day-skipper, and also with 'cycle' timers... except all timers with rotating dial could be called cycle timers, but 'cycle timers' are normally timers with less than 24 hour rotation period.
Gene h
Mar 24, 2014 | Intermatic Hardware & Accessories
I installed a new T104 m for my pool pump. The clock works fine and it works fine manually. The on and off stops do not turn it on or off. The clock goes right past the on and off stops and they don,...
You installed new 240Volt T104 Intermatic timer.
Cause of problem is not determined, so read information below and then add a comment with further observations.
According to question:
Timer is wired correctly.
The on-and-off trippers are installed on dial, but do NOT click the override lever back and forth.
Both ON and OFF trippers are on the dial.
And the timer is NEW and not used, and trippers are NEW and not used.
And the dial rotates and keeps good time, making 1 full rotation each 24 hours.
And the manual override lever works and turns load (pool pump) on-and-off.
Open following link to view photo image of OFF tripper coming in contact with manual override lever.
Trippers are soft metal, and made to wear down. When tripper gets old, it will slide over the lever instead of move the lever.
http://waterheatertimer.org/images/WH-lever-005-500.jpg
Open following link to read how to set timer, and see close-up images of timer with trippers on dial, and tripper order number for replacement trippers.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
I am trying to learn how to set up the T104 timer etc. I just moved in and there is no manual how to set timer.
Here are two links that will be handy to keep on file:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
T104 is 240Volt timer.
When you open the door, there should be piece of translucent plastic covering the wiring.
As long as plastic cover is in place, it is safe to touch visible timer parts.
If you have a child who might stick something into the timer, then lock timer door.
As a general rule with electrical devices, do not stand on bare ground or wet surface or lean into or touch anything metal while working on timer. Put down dry boards. Same with your circuit breaker panel.
The T104 yellow dial rotates just like a clock.
The dial has ON and OFF trippers attached to outer edge of dial.
As these trippers rotate around they move on-off lever that turns the pool pump or Load on and off.
ON tripper moves lever one direction, and OFF tripper moves same lever other direction.
The manual override lever clicks back and forth with audible sound each time tripper moves on-off lever.
Move manual override back and forth and it will turn Load on and off.
Override should snap crisp and clean.
To set timer, lift and rotate dial until current time lines up with stationary silver pointer.
Stationary silver pointer is pointed at 6:00.
Upvote the help.
May 22, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic pool timer E10694 does not turn on. It shuts off okay.
Open following link for troubleshooting checklist:
If dial is rotating, then tripper might need to be replaced.
The problem here is I cannot identify E106 timer
Intermatic product Index, and pool and spa catalog do not show that specific model among digital or mechanical timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Maybe you have T106 2-speed pump motor?
Add a comment with in-focus photo of timer you posted on Flickr for possible identification.
Upvote the help.
May 17, 2011 | Intermatic T104 24h 208-277v Mechanical...
How do i reset my pool timer after it has been switched off for awhile
If this is Intermatic box-type timer, lift and rotate dial until current time lines up with silver pointer.
http://waterheatertimer.org/images/T-104Large-550.jpg
The pointer is stationary at 6:00 position.
Places on-off trippers on dial at times you want pump to operate.
Dial rotates as time passes, and trippers move switch lever that turns circuit on-off.
manual override lever is connected to switch lever, and manual override clicks back and forth with audible sound each time circuit turns on-off.
Buy extra clock motor and trippers at Grainger.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 19, 2011 | Hardware & Accessories
I HAVE AN iNTERMATIC t100m TIMER it appears to have two "off" tripper levers but no "on" tripper lever attached to the clock face dial by a set screw . Do I need an "on "...
Yes, the T101M 120Volt pool timer requires both ON and OFF trippers:
Grainger sells T100 series on-off trippers:
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Amazon sells T100 trippers
http://www.amazon.com/dp/B003YO2C5U/?tag=picc-20
Grainger sells the T100 125V clock motor
How to wire T-101 120Volt timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
How Intermatic dial timer clock works.
Clock motor rotates dial.
Intermatic clock motor, located on back of mechanism, are replaceable
Trippers located on outer edge of dial push on-off lever
ON tripper pushes lever one direction
OFF tripper pushes lever opposite direction.
Lever pushes electrical contacts together and pulls contacts apart.
When lever moves, manual override also clicks back and forth with audible click.
To replace timer, replacement snaps into box without needing to changing box.
Dec 10, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Brand new Intermatic timer for pool, but it will not trip the pool ON...It does trip the pool OFF only??????
So you can turn the pool timer off using manual override.
The center dial is also turning.
These 2 things mean the timer is working fine, but you forgot to put the OFF tripper pins on the dial.
5def96a.jpg Picture shows Off tripper coming in contact with lever that clicks lights on and off. The lever is connected the manual override. So if manual override is working, then the lever is working.
1ba8aca.jpgThe ON and Off trippers are different color
Oct 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic Pool timer will not turn off... I have to shut off the pool pump at the breaker... Any suggestions on what the problem might be?
If the pool pump timer is not working, first look and see if the clock dial is moving, if not then you need to check the 120volt breaker that feeds it ,, then you would check the connections on the timer to be certain that they are correct.
Jan 18, 2010 | Intermatic Timer T12404R Pool & Spa...
Intermatic EI220 Electronic Auto Shutoff Timers Logo
938 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
