HTC P3300 Smartphone
Problem for HTC P3300 Smartphone
Touch screen do not respond
By Ravindra H S on May 10, 2008
At times, Touch screen does not respond and phone cannot be unlocked by no means, Problem do not get solved even after restarting phone, removing battery & reinserting etc.. This happend typically during nights when the phone is not used and in the morning, touch screen does not respond to do any activities.
Comments:
May 20, 2008
- I cannot use / interact using Touch Screen on my HTC p3300 phone. I cannot predict when touch screen freezes to respond. I used lock the phone with a password and when touch screen does not respond, there is no way by which phone can be unlocked. Now I started invoking the cursor and whenever touch screen freezes, I use the cursor and manage some how.
Same Problem
Jul 07, 2008
-   I've tried to take off the battery, restart the phone and also hard reset and the touch screen is still not responding. please help-   Guest
Jul 01, 2008
-   Soumitra Ghosh from Kolkata.....
Having the same problem...within one months of purchase, touchscreen became non-functional, then after repairing, within a weeks time, the touchscreen went blank and it hangs quiet often as well. Again given to service centre for repair / swap, whatever they feel. It's ridiculous that they dont replace. this time, after receiving the transreceiver from the service center, if the problem persists, i'm going to drag them to consumer court.That's for sure.-   soumya250
Solution #1
posted on Jul 18, 2008
Not Rated)
maxliang600
Rank: Apprentice
Rating: 0%, 0 votes
if u guys have a htc touch and you just happened to remove the baterry when it hanged.. the touch screen wouldnt work =/... this first time it happened to me.. i went to the dial menu and reseted my phone.. amzingly it worked... but this time my phone hanged again and i removed teh battery. now i cant get into the dial menu and couldnt reset it =(
Was this helpful?
Yes
No
Solution #2
posted on Jun 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yes ; reset to factory deafualts by hard reset is that again normal. i also got the same trouble.
to do hard reset search out on google.
you can also flash your complete rom then there will be no such problem
Solution #3
Not Rated)
sanjeevsaini
Rank: Apprentice
Rating: 0%, 0 votes
I cannot use Touch Screen option at bottom & top, only center part is ok on my HTC p3300 phone. Secondly keypad does not work with stick but with cursor it is ok. please suggest how to solve this.
Was this helpful?
Yes
No
Solution #4
posted on May 19, 2008
Not Rated)
devilrules
Rank: Guide
Rating: 83%, 5 votes
could you explain in detail what s happening with your phone??
u said that ur phone cannot be unlocked...but then u say that it happens typically during nights...do u mind elaborating?
Comments:
May 20, 2008
- it is possible that ur pda is virus infected and it freezes the touch screen...if that is the case then just reset the device to the factory conditions...
settings-> clear storage
that might help...but do remember to take back up of ur contacts and important files...
secondly if the above step doesnt work then its definitely hardware...moisture, low temperature there could be n number of reasons for that..so just take it to the service centre...
Was this helpful?
Yes
No
Popular Solutions for HTC P3300 Smartphone
Questions and Unsolved Problems for HTC P3300 Smartphone
Do you recommend HTC P3300 Smartphone?
Answer
Answer
bsnl gprs setting for samsung c6625 cn u provide
Answer
cannot synchronize my phone, showing error code 43
Answer
Hi I am using Ultimate 8150 (Imate) and its giving "Tap the screen to set up your windows... (More)
Answer
i want acess internet through BSNL postpaid
Answer
I use htc mobile and contact to internet via Wimax.The connection is good but can not find the page... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDAs Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
