Question about Xerox Phaser 8500/DN Printer
Xerox 8400DP works fine with all the other computers in the office, but with a new Win 7 machine, it insists on printing from Tray 1 (Multipurpose) and printing in Black and White, whether Preferences is set to Automatically Detect or to Tray 2. Driver installed is for Win 7. Thoughts?
  • ed24420 Sep 01, 2010
    I am working with the driver you link to - that is the one causing the problem. HOW do I change the feature set and color correction settings for the driver?
  • ed24420 Sep 03, 2010
    Thanks - a reinstall of the same driver file seems to have fixed the problem. The original install indicated "Color Support: NO" on the test page printout - second install (same file, same machine) reversed that and things seem fine now. Tx for the suggestions.
  • 4,924 Answers
Http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=8500_8550&Xlang=en_US&Xcntry=USA
download and reinstall the driver for it ...but remove all related software first ..go to the program files after removing the driver and the software related..and remove any folders that might have to do with previous installations...
after that reinstall it clean and give it a try ..
It might have something to do with the fact the it is connecting in network ..and may not be compatible ..or ..it might be just a strange settings ..and reinstalling it will default it ..
Posted on Sep 02, 2010
  • Catalin Turcu
    Catalin Turcu Sep 02, 2010
    if you reinstall the driver it will be defaulted to the original settings ..so you do not need to change them ..if it will continue to do the same ..than it is an incompatibility of the windows 7 and there is no fix...try to put it directly to the windows 7 computer ..and see if it works ..if it does..than it is an issue with the network relation ..probably it do not have a common ground to share with the others working on xp ..but only the B/W printing ..
    I would download and try the vista driver and see how it works on 7 ..cause sometimes they are compatible ..and the vista one may be much receptive to the network ..
  • 229 Answers
The problem is a bad diver configuration do this :
When the driver installed, it selcted "basic printing" as its feature set.
also had to select "none" for color correction.
if dont work download the last PostScript driver from here :
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=8400&ripId=&Xtype=download
please rate me :)
Posted on Sep 01, 2010
I am using hp 3505 color lesser printer on windows 7 32bit, Driver that was installed automatically by windows is "HP Color LaserJet CP3505 PCL6" My tray 1 that is multipurpose tray is printing slo
Make sure that you have tray 1 set for the correct paper type. Leaving the paper type as unknown will result in very slow printing as the printer will assume that it might be printing on heavy media, envelopes or the like.
Feb 02, 2015 | HP Office Equipment & Supplies
Can't print from office 2010 software
uninstall the drivers again and find the printer manufacturer web page , get you printer model and the download for win 7 and install from there
win 7 is no longer supported so win 7 drivers will no longer be compatible
Dec 21, 2017 | Dell 5100cn Laser Printer
Cant get my lexmark platinum pro905 to print from tray 2 using microsoft office products
If you're unable to print on Tray 2 using MS Office 2010, please follow the instructions in this article from the Lexmark website to fix the problem.
- Unable to Print on the Tray 2 Using Pro900 Series Printers from Microsoft Office 2010 and Internet Explorer 9
I hope this helps.
Jan 09, 2012 | Lexmark Platinum Pro905 multifunction...
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
Can I use Work Centre 470cx with WIN 7?
You can downlad the vista driver from the xerox website and try but 470cx is not supported yet with windows 7 http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=470cx&ripId=&Xtype=download
Nov 21, 2009 | Xerox WorkCentre 470CX InkJet Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Xerox 8400
The normal cause of that is the pre heater has failed.
Part no. Preheater and Deskew Assembly 1 119641980
You can call 1-800-831-6100 for a price.
May 19, 2008 | Xerox Phaser 8400DP Thermal Printer
Xerox Phaser  8500/DN Printer Logo
186 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
