Question about Standard Horizon CP175C GPS Receiver
My standard horizon gps chart 170c model #p1msf20gsd1, serial #21020184 will power up, but i cannot get any of the readings on the lcd., although it was working perfectly well on my last fishing trip which was 8/26/10. when i went on the last fishing outing on 8/30/10 i turned the gps on at the dock but although the sceen light came on, no other functios worked. the wire appears to be ok. i hope that you can help me. thank you. lou
3 Suggested Answers
  • 4090 Answers
SOURCE: standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Posted on Jun 30, 2009
drifterK
  • 4924 Answers
SOURCE: My Standard Horizon gp175c starts
http://www.mediafire.com/file/i5abiua3u39e71j/S3egSH7c315c-030504eng150.pdf
Thi a A LINK FROM WHERE i SUGGEST TO DOWNLOAD THE MANUAL ..aT THE PAGE 71 IT IS THE TROUBLE SHOOTING ..AND IT IS EXPLAINED THE RESET RAM PROCEDURE..tHIS WILL RESET IT TO THE ORIGINAL FACTORY SETTINGS ..AND ALSO DELETE THE USER SETTINGS ..AND THEY WILL HAVE TO BE MADE AGAIN ..
Another thing I would try before reset ..is to remove the card and see if it boot up ok ..If it does it means some data on the card are unreadable or so ..and you will probably need to update the charts and all ..But first make sure it boots up ..and reset it to take it from scratch ..
Follow procedure to get into the system test menu ..(turn off the chart-plotter ..and hold a key down ..and press to turn on the chart-plotter ..)
I suggest to make the reset first without the C card inside ..and if it is not corrected ..to it with the card inserted..maybe some settings are stored on the card ..
if you can ..back-up the maps and such first ..
Posted on Aug 10, 2011
Why does My 170c is not receive signal. It shows "acquiring" all the time
It is not "linking" the GPS signal to your GPS receiver. There may be a "dead spot" you are in or the unit itself has a malfunctioning RF unit within the GPS receiver.You cannot be under a bridge or other obstruction with a GPS unit for signal to reach it.
Aug 10, 2014 | Standard Horizon GPS
I need an operating manual for a Standard Horizon CP155c chartplotter
please call Standard Horizon Marine Support 800-767-2450 and they will email you the manual.
marinetech@vxstdusa. com
Sep 10, 2010 | Standard Horizon CP155C GPS Receiver
Integrating AIS, Radar, Autohelm 7000 and flux gate compass.
ActiSense makes a programmable multiplexer that should do this for you. It is called an ActiSense NDC4 USB. Not sure is the Standard requires a separate compass signal, but if not, and the Standard can use a standard 38000 baud AIS data stream, the NDC4 will work for you. 847-746-0100
http://www.blueheronmarine.com/Actisense-NDC-4-USB-NMEA-0183-Multiplexer-with-USB-Port-6334
Jan 30, 2010 | Standard Horizon Cpv550 Gps Chartplotter...
Standard horizon 155c not acquiring signal
Jun 30, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
I am trying to delete all tracks/routes on CP180 Standard Horizon
reading your owners manual (link provided at below) , i see you can delete / edit points one at a time or a faster way format the C Card.
** formatting the c card instructions >
1.) press MENU , move the shuttle point knob to highlight USER POINTS , and press ENT .
2.) move the shuttle point knob to highlight USER C CARD, and press ENT .
3.) move the shuttle point knob to highlight FORMAT ,
and press ENT .
4.) a popup warning window will pop up to confirm you want to format the user C card .
5.) select YES , and press ENT to confirm , (select NO otherwise) .
NOTE : formatting the user c card erases all files previously saved on the c card .
CP180 users guide
J5
Jan 17, 2009 | Standard Horizon Chart Plotter CP180 GPS...
CP 160
I can not put the name of the points on my gps chart 160
May 26, 2008 | Standard Horizon CP160 GPS Receiver
Orientation
It is not likely that there is a software error that could cause that problem so I'm going to cover some basic information first. Forgive me if I'm covering stuff you already know. There are 3 chart orientation modes, North Up, Heads Up, and Course Up. North Up you already know! In Heads Up mode, the chart will only orient heads up when the boat is moving. Unless you have an electronic compass interfaced to your GPS it has no way of knowing which way you are facing. Once you start to move, it compares your new position to the old position to determine which way is heads up. If you are not moving, the map defaults to North Up even if you are in heads up mode. Course Up mode is commonly mistaken for Heads Up. In Course Up mode, the GPS orients the top of the screen toward a waypoint that you have told the GPS to go to. If no waypoint is selected, the GPS will default to North Up orientation. So I guess what I'm saying is, make sure the boat is moving, and make sure you're not in course up mode (unless you want to be).
In the unlikely event that there is a software error causing this problem, it can easily be fixed by getting an update from Standard Horizon. You can either get them to send you an update chip, or download it online and copy it to a blank C Map card. When you turn the GPS there will be a message on the opening screen that identifies you software version. Get that information before you call Standard.
Feb 13, 2008 | Standard Horizon CP-1000C GPS Receiver
Power cord
I called standard horizon myself and bought the power cord for $25. The # 714-827-7600
Nov 12, 2007 | Standard Horizon CP150 GPS Receiver
Standard Horizon CP175C GPS Receiver Logo
242 people viewed this question
Top Standard Horizon GPS Experts
Steve
Steve
Mike Mullett
Mike Mullett
Level 1 Expert
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
