Question about Philips GoGear HDD6330 MP3 Player
Connect to pc
Evry time i turn my mp3 player on it says philips then go gear then ti says please connect player to pc how do i fix that
  • 6 more comments
  • derek h May 16, 2008
    i also have the same problem only device manager will not recognize it.
    the pc realizes there is a usb drive but will not show a folder in the
    my computer folder... also the "safely remove hardware" pops up and you
    can look at the gogears drivers in properties, accessed through the
    saftly remove hardware icon... the drivers were missing so i tried
    using the automatically find and install drivers option, it installed
    the microsoft 5.1.2535.0 driver which didnt change anything in the
    devices behavior. i tried using the update driver option through a
    specific path to the new firmware release but that also didnt work-
    wrong format wouldnt accept.
    thanks,
    derek.
  • Anonymous Jun 05, 2008
    IItronics mp3
  • kmcrummett Jul 15, 2008
    I have the same exact problem as derek. I would love any help at all.
  • Anonymous Aug 08, 2008
    will not read device
  • MONEYMIZLOVE Sep 15, 2008
    MP3 WILL NOT PLAY MUSIC ONLY SAY CONNECT TO PC GO TO DEVICE MANAGER
  • Anonymous Oct 12, 2008
    device manager
  • info112 Feb 02, 2009
    I am asked to connect to pc any time switch my philips 110/5
    on
  • Anonymous Feb 06, 2009
    how i can do repair my mp.3 player
When i turn he say please conect the pc and use the device manager
Posted on Jun 02, 2008
    Problem Solver:
  • 5 Answers
My HDD6330 just stopped connecting and working on 05/25/08. Windows XP, SP2. Media Player10. The player works fine for everything that is already on it. When hook up to the USB, and it tries to establish a connection, the little screen just freezes up.
any clues?
Frank
Posted on May 27, 2008
I also have the same problem only device manager will not recognize it. the pc realizes there is a usb drive but will not show a folder in the my computer folder... also the "safely remove hardware" pops up and you can look at the gogears drivers in properties, accessed through the saftly remove hardware icon... the drivers were missing so i tried using the automatically find and install drivers option, it installed the microsoft 5.1.2535.0 driver which didnt change anything in the devices behavior. i tried using the update driver option through a specific path to the new firmware release but that also didnt work- wrong format wouldnt accept.
thanks,
derek.
Posted on May 16, 2008
  • 476 Answers
Sounds like the system files have been corrupted or deleted.
The HDD6330 is only compatible with Windows XP (With Service Pack 2) & Windows Media Player 10. If you have version 11, you will need to uninstall it to roll back to version 10.
Install and run the Philips Device Manager from the product CD.
Connect the player to the power supply and PC.
If the player is recognised by the PC, select the repair/restore option in Philips Device Manager, and follow the on-screen prompts.
This will format the player and re-load the firmware.
NOTE: THIS WILL DELETE ALL TRACKS ON THE PLAYER.
If this doesn't help, then post details of what happens, and I'll try to help further.
Posted on May 14, 2008
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
I have philips go gear 1gb ipod. ...the moment i
You have to go to Philips website and download the Philips Device Manager for your model. Once you have installed it, run the Repair function.
-Tha Mp3 Doctor
Feb 24, 2009 | Philips GoGear SA178 MP3 Player
My player(hdd1830/17)is not booting and not shuting down?
Reset ti first, and see how it behaves. If that fails:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 24, 2009 | Philips GoGear HDD1830 MP3 Player
Format player
Use the Philips Device Manager to run a Repair on your device - it will give you instructions, and enable you ti fix your player.
-Tha Mp3 Doctor
Jan 25, 2009 | Philips GOGEAR SA6045 MP3 Player
REPAIR MP3?
Hello - doesn't anyone listen. Connect the player to your computer, and open the Philips Device Manager, and run a repair.
-Tha Mp3 Doctor
Nov 26, 2008 | Philips GoGear SA3125/37 MP3 Player
Zeri volume
-Tha Mp3 Doctor
Nov 02, 2008 | Philips GoGear SA3125/37 MP3 Player
I dont know why it is doing this please help i wish god could bless u if u do
This player will do that if it is connected to a pc running Vista or Windows Media Player 11
try the Repair in Philips Device Manager
if it says "failed to repair," the player is done
Jul 30, 2008 | Philips HDD1630 MP3 Player
Mp3 player
please help my player to work again
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Philips mp3 player
whenever i turn on my philips 1gb gogear it says player problem connect to pc.
Feb 01, 2008 | Philips GoGear HDD6330 MP3 Player
"Please connect player to PC"
Go to www.philips.com and download the hhdd1630/17b software and firmware updates. Install them and print off the instructions on what to do. This fixed my player and what a difference it made.................WOW
Sep 11, 2007 | Philips HDD1630 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
268 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
