Question about Technics Audio Players & Recorders
Technics reciever model su-g95
My reciever took a dump, I need to find another one like or one that is compatabile with the Technics stereo. Is there one out there that I can use, or do I just chuck this one and get a new stereo?
SOURCE: SU G 95 MANUAL
Go to http;//audio.manualsonline.com maybe there you find it.Good luck.
Posted on May 25, 2008
petraman7
  • 1175 Answers
SOURCE: need owner manual for technics amplifier su-g95
www.stereomanuals.com
He's big into Technics
Posted on Feb 25, 2009
smarthome2
  • 1114 Answers
SOURCE: Tecnics SU-G95 stereo overloaded
Power down,disconnect the speakers and power back up. If it still say's overload, it needs to go to service. If not, check your wires, connections, and speakers one by one to hunt down the problem and correct. Hope this helps
Posted on May 25, 2009
SOURCE: Technics SU-G95 Amplifier, Intermittent popping/crackling noise
The heat sink has the power modules attached but also has 2 power transistors that become disconnected from the circuit board when the heat sink moves or flexes. The pins on each need to be resoldered (it helps to bend them a bit too, prior to soldering). Had the same problem on the same amp today and that was the fix. There was no sound other than a clicking when the volume control was rotated.
Posted on Dec 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a Technics stereo integrated amplifier SU
It chirped because the bearings were worn out, then it froze up and isn't moving any air. Get it replaced. DO NOT run the unit if it keeps overloading or you will have a bigger problem.
Posted on Dec 27, 2009
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
Need help with part numbers for replacement
values of D731,D732,Q733,Q732,Q735 and Q737
Q733 = 2SB321AQSTA
Q735 = Q737 = 2SA992EFPTA
Q732 = Q733 = 2SC3311AIRTA
D731 = MA436MTA
D732 = MA165
Sep 30, 2012 | Audio Players & Recorders
Any extra remotes??
No other remote control will work with this set. You must have its original remote control. Contact the nearest Technics authorised service center for details.
Mar 30, 2012 | Televison & Video
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
My technics intergrated amplifier says over load
overload is protection from very big signal input-or high current output.
1-keep your input signal between -10db-----to 0db.
2-confirm that amplifier power is greater than total power of loudspeakers by 20%(if loudspeaker total power is 8 watt-amp watt must be 10 watt at least.
Nov 30, 2009 | Technics SUV500 2-Channel Amplifier
I am playing my stereo with the su-g95 amplifier what can i do to play all 4 speakers at the same time.
first dose your amp have 2 or 4 outputs if 4 outputs you have to have 4 speakers ,and connect them on your amp speaker output is that so hard to do ....
Nov 17, 2009 | Technics SUV500 2-Channel Amplifier
May 25, 2009 | Technics SUV500 2-Channel Amplifier
279 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
