Question about Sharp AR-168D Copier
SPF/RSPF JAM ON AR-168D COPIER - Sharp AR-168D Copier
Bubbabear64
  • 2794 Answers
SOURCE: Error Message: Check SPF/RSPF START to Resume
Sometimes the ribbon cable that sits under the scanner jams the scanner. Taking the scanner glass off and securing it with scotch tape fixes the problem.
Posted on Aug 09, 2008
  • 990 Answers
SOURCE: Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Posted on Aug 26, 2009
Sharp Tech
  • 63 Answers
SOURCE: Problems with SPF message and black copies
The "Check SPF/RSPF" issue can be a couple of things
  1. If the scanner only moves from right to left then immediately moves back then the copier needs to be adjusted.
  2. If the scanner moves from right to left and tries to feed then displays message then the ADF needs to be cleaned.
Same for the dark issues
  1. If you lighten the exposure and the copies come out better then copier needs to be adjusted
  2. If you lighten the exposure and the copies come out the same then you may have a few problems check the following;
  • Open right side door and look at drum green/blue cylinder . If it is covered with toner (black film) then you might have a drum short.
  • Open right side door and look at drum, if it is not covered then you may have a board issue.
While making a copy off the glass listen to the right side of the copier and if you can hear a screeching sound then you could be having an electrical short that is causing your black copies.
Depending on your findings depends on the remedies.
Posted on Oct 17, 2009
  • 9 Answers
SOURCE: message CHECK SPF/RSPF and will stick on scan
In the Jaguar series, (ar-168d) you will need to get into the simulations; press in rapid succession: # * C * You will know when you did it fast enough when all the display lights go out except the number display, press 41 start/copy. then 6 start/copy. Let the copier do what it needs to.
The scanner will move, keep the lid down, it will let you know when it is done when it goes silent. Then press CA key to clear out and try copies again.
Posted on Jan 04, 2010
SOURCE: Error on Sharp AR-168D Copier
The manual says to turn off and unplug the machine and wait for 10 seconds. Then plug it back in and turn it on. If this doesn't get rid of the problem contact your sharp dealer/service man.
Posted on Feb 11, 2010
My AR-168D is having doc feeder problems.If paper is loaded intpo the document feeder the light comes on that recognizes the paper is loaded.When i press copy nothing happens but the scanner moving over to...
Thats pretty easy to fix. Remove the glass. You lift the document feeder out and remove the 2 screws from the front and back of the glass.
Once the glass is removed, Take some rubbing alcohol, or good cleaner. Formula 409 , fantastic etc, dampen a cloth towell and clean the stainless steel shaft on the rear of the scanner that the lamp rides from left to right on.
I bet if you try and move the scann lamp carriage it is very hard to move.
Clean it a couple of times. Get e very light weight oil and put a light ammount on that shaft. Run the carriage back and forth a few times, clean and relubricate the shaft and you should resolve the problem.
Very common. I would say there is a 99 percent likelyhood that this will fix your problem.
Aug 09, 2010 | Sharp AR-168D Copier
Message CHECK SPF/RSPF and will stick on scan often.
Dec 15, 2009 | Sharp Office Equipment & Supplies
Tryong to use top feeder, it keeps reading
SPF is normal document feder
RSPF is autoreverse document feder.
Select the your document feder instaling the copiers,remove any originals to the glass.
Oct 21, 2009 | Sharp AR-168D Black and White Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
Mar 16, 2009 | Sharp Office Equipment & Supplies
Drum replacement
open the right side door.open the front door.unscrew the devoloping unit lock screw. pull the unit out. pull drum unit out fromthe copier.
Feb 16, 2009 | Sharp AR-168D Copier
I just fixed this problem on my sharp all in one. The white rollers on the underside of the copier cover were not rolling well. I took an alcohol prep pad and started cleaning them, rolling as I went. A large piece of lint fell out. I put the documents in the document feeder and they fed through like a charm. Hope this helps.
Aug 06, 2008 | Sharp AL-1655CS Copier
Sharp AR-168D Copier Logo
509 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
