I have a TOSHIBA MK5055GSX ATA Device (hard drive) which i have used as the internal drive of my dell latitude d630 . currently it has given me a notification or rellocated sector count (bad sector). I can see the lable of that partition. The problem is actually with just a partition. When i am viewing the disk with partition magic, i am able to see the used space as well as space left etc but cant explore it. if i try it tells me the volume does not contain a recognised file. Also says to is either make sure all required file system drivers are either loaded or volume is not corrupt. I dont want to format what should i do now please.
4 Suggested Answers
Prashanth108
  • 82 Answers
SOURCE: My sea gate external hardware
Please right click on the External Hard Drive in My Computer Window and select Properties.
Then select Tools TAB and click Disk Check.
You can also format the Hard Drive using NTFS File Format.
Posted on Feb 27, 2011
TimeDefensiv
  • 746 Answers
SOURCE: hard disk has alot of
Use Hard Disk Regenerate software, your problem will resolve with 100% guarantee.
Best of Luck
Posted on Mar 14, 2011
Geekman
  • 32281 Answers
SOURCE: i got a maxtor ide
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Posted on Jun 25, 2011
How to install a wind iows 7 os when nothing is going into internal memory
As long as the connection interface isn't different, the Rpm does not matter.
Here's a walk through on how to install the drive.
http://blog.parts-people.com/2011/08/15/dell-latitude-d630-hard-drive-and-caddy-removal-and-installation/
The Bios should automatically recognize the new drive. You can go ahead and install the operating system from a bootable cd or usb.
Aug 19, 2014 | Dell Latitude D630 Notebook
Have dell latitude d630 laptop had widows vista won't re boot says no internal drive no boot able devices help me hard re boot system Without disk
your hard drive gone. you will need to get another hard drive, install it and place your old hard drive in an external holder and see if you are able to still access it.
Jul 28, 2014 | Computers & Internet
Hi got an dell latitude d630, swithes off after an
Have you considered it might be overheating? Does the fan make a loud sound after a few minutes?
Also here you can find technical documents on this model, http://www.dell.com/support/Manuals/us/en/19/Product/latitude-d630
Aug 27, 2013 | Audio Players & Recorders
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
I have installed a Toshiba MK5055GSX Cache
It is referring to your PS3 Firmware. Update the firmware, then install the new drive.
Feb 11, 2010 | Sony Video Game Consoles & Games
Replacement hdd for a Toshiba MK4026GAX (ATA)
Any brand-new ATA hard-drive (you probably won't find any new hard-drive smaller than 80GB) will be compatible. Pay a few extra dollars for a 7200 RPM drive (rather than 4200 or 5400 RPM).
Nov 14, 2009 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Hard drive
Sounds like your hard drive is toast but £145 for sony to replace it sounds expensive, you should just be able to replace it with any 2.5" internal sata drive
here is an example of one
http://www.play.com/PC/PCs/4-/9663375/Toshiba-MK5055GSX-500GB-2-5-Internal-SATA-Hard-Drive/Product.html?source=5066&engine=froogle_pc&keyword=Toshiba+MK5055GSX+500GB+2.5%22+Internal+SATA+Hard+Drive+(Sony+Playstation+PS3+Compatible)
That one is about £80 but im sure you can find cheaper, the best news is that replacing the drive doen't void your warranty which is good, here is a link to really good guide for replacing your ps3 hard drive
http://boardsus.playstation.com/playstation/board/message?board.id=ps3media&message.id=62981
good luck, let me know how you get on
tim
Jul 04, 2009 | Sony Playstation 3 (PS3) Console
Dell d630 hard disk and bios admin locked need help-
If you have forgotten your BIOS or Hard Drive Password for this model, there is a master code that you can obtain from Dell Support. Simply call, Email, or use Online Chat from http://support.dell.com and give them your Service Tag, and they can help your out from there.
Feb 26, 2009 | Dell Latitude D630 Notebook
Computers & Internet Logo
651 people viewed this question
David Payne
David Payne
