Microsoft Xbox Console
Problem for Microsoft Xbox Console
Original XBOX error code 07
By XBOX Hater on May 10, 2008
I get the dreaded red light with the call service center and error code 07... What to do?
Clarification Request
Posted by mevan64 on Sep 24, 2008
Please tell me how to make this ....\
There are no agents in my country to make it.
Same Problem
Sep 26, 2008
-   when i turn it on it goes green then shuts of then restarts it self and turns green and turns of and restarts itself about four times then it starts flashing green and red-   lebron james
Sep 20, 2008
-   my xbox has the flashing dreaded red light of death and i don't know what to do without going to get it repaired at a repair shop-   Guest
May 26, 2008
-   The red light has come on and the message on the screen saying that you need to get the xbox serviced. Does any one have this problem or know how to fix it with out taking it to a repair store.
-   gazza12345
Best Solution
posted on May 29, 2008
Helpful)
S_n_A_k_E
Rank: Wiz
Rating: 84%, 55 votes
The only way to replace the hard drive is using a mod chip. You will also need the "config magic 2" program. The hard drive is digitally "locked" to the motherboard using the serial number of the motherboard and hard drive. If you change the hard drive you will still get the same error. I do modifications including bigger hard drives. If you have any questions email me. My email address is
xboxmods_4u@yahoo.com
Was this helpful?
Yes
No
Solution #2
posted on May 10, 2008
Helpful)
XBOX Hater
Rank: Apprentice
Rating: 76%, 5 votes
Found out through Microsoft that code 7 is a HDD failure. Only wat to fix is to replace the HDD.
Was this helpful?
Yes
No
Solution #3
posted on Jul 26, 2008
Not Rated)
sanjuro77
Rank: Wiz
Rating: 89%, 36 votes
You actually don't need a modchip. You can do a softmod, but it'll take a bit of work, a new hard drive, and about $5 in parts from Radio Shack. Everything you need to know you can find here:
http://forums.xbox-scene.com/index.php
(you'll have to look around to find what you need, but it's all there)
and
http://llamma.com/xbox/Repairs/Reading_Xbox_Hdd_key.htm
(the thing you need to build)
Was this helpful?
Yes
No
Solution #4
posted on May 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
are u sure ther's no other way not even to tamper with it?
Solution #5
posted on May 17, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
wat is hdd
Popular Solutions for Microsoft Xbox Console
Questions and Unsolved Problems for Microsoft Xbox Console
Do you recommend Microsoft Xbox Console?
Answer
Answer
my xbox has an error and it said wipe it with a soft cloth i done it and it still wont come on
Answer
The screen went green when playing and now says no signal
Answer
i was playing on my origonal XBOX. i heard clicking and what sounded to be skipping, then a red ring... (More)
Answer
hi my xbox has two red bits on the power button and keeps coming up with contact xbox can not play... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
