Question about Cameras
I have Sony cybershot 12.1 megapixel camera with a song 4GB memory card. Everything was working fine untill I tried to insert it in the computer and it did not register it was indersted. I then tried putting it back in the camera and the message Reinsert the memory stick came up, with C:13:01. The memory card contains very important pictures and I NEED them back asap!
    Brigadier General:
  • 11,967 Answers
Your pics are still there. When you pulled out the card from the computer, I'll bet you didn't use the "safely remove hardware" function. That's why your camera now doesn't recognize the card. You could try using a card reader or you could take the card to a store like Walmart and use their picture machines that make pictures while you wait.
Posted on Sep 01, 2010
Why my sony steadyshot camera dsc-w180 memory is not recognise to my laptop when inserted, but it support when i inserted to my camera, i want to transfer file to my laptop but no way please give me y
It is not only the card and computer or camera and computer that is needed. To interface anything to a computer you need a program. Most of the time called a driver. When you put a card reader to the computer, or when there is a card reader in the computer you need a driver that came with the card reader or the computer. To read from a camera, you need a driver that came with the camera. More and more, the interfacing of cameras becomes standard, so if you ever installed a camera driver it could be other cameras can communicate with your computer. But no guaranty it always work.
With the correct driver, your camera acts like an external memory to the computer and the computer can read the pictures on the memory card in the camera.
So if you use a card reader or a camera on the computer always meme sure you have installed the correct software that came with the apparatus.
Jan 26, 2014 | Sony Cybershot DSC-W180 10.1MP Digital...
Pictures on memory card not showing up on camera (DSC-T70)
You most likely did not safely remove the card from your computer and corrupted the cards MFT. You will need to format the card in the computer. It should work after that.
Jan 30, 2013 | Sony 4GB Memory Stick PRO Duo Memory Card
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
How to unlock memory card for sony cybershot 10.1 megapixel
the memory card Sony, called memory stick have a slider in right side. Slide to unlock and you can continue using you memory stick.
is important for people to share knowledge to hear your comments, rate points
Sep 16, 2011 | Sony Cyber-shot 10.1-Megapixel Digital...
Was using a 4GB SanDisk memory card and a Sony CyberShot (new that worked well with this memory card for 12 days and works now with other memory cards) and taking lots of pictures and video then all of a...
The card appears to be defective. Replace the card.
There is a small chance if some crud on the contacts, but sounds like you have removed and inserted a few times.
Return it to where you bought it.. for exchange or refund.
You could try to format the card in a PC, but even that sounds unlikely by your description.
If you can see the card in the PC there is SoftWare that can try to recover defective pics from card.
But if you can not "see" the card in a PC, the SW is a waste of time.
link to google search for SW
http://www.google.com/#sclient=psy&hl=en&safe=off&q=recover+pictures+from+memory+card&aq=0&aqi=g4g-o1&aql=f&oq=recover+pic&gs_rfai=&pbx=1&fp=1d02e3dd4442100f
Nov 16, 2010 | SanDisk 4GB microSDHC Memory Card
I have a new sony memory stick pro duo 4GB magic gate and it came with an adaptor...I only have a few photo's on it but wanted to try it out. I tried inserting with and without the adaptor into my HP C5180...
try pluging it straight into the pc with a card reader and see if it picks up, this could also be a camera formating problem so try formating it in your computer.
hope this helps and good luck
Nov 09, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Can't download the pictures from my Sony Cybershot camera
maybe you inserted the memory card improperly? this happened to me too.
Jun 06, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Dsc-s700 format error
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Format Error in Sony Cybershot
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Jan 02, 2008 | Cameras
Cameras Logo
152 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
