Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
My camcorder will no longer record. When I press the record button it just switches modes.
    Scholar:
  • 95 Answers
The mode switch assy includes the record button. You either have a bad connection or a bad mode switch assy. This repair would need to be done by an experienced technician. www.austintelstarservices.com
Posted on Sep 02, 2010
When I press the power button on my ultra hd 2nd generation camcorder, the screen lights up with the flip logo and verbage that says hold the record button for setup. It also makes the correct sound for...
Will the camcorder let you go ahead and complete "SETUP"?? if so, go ahead and redo the setup maybe some glich and maybe doing setup again may get the camera going again? hope so!! I have one also and knock on wood, no problems so far. it may be worth a try:
when camcorder turns on: when Flip Video Logo comes up press and hold RECORD button, to enter setup mode use the + and - to adjust current setting and the left and right arrows to select other settings
good luck!
Apr 25, 2011 | Pure Digital Flip Video Ultra Camcorder
Goes from record mode to standby automatically
Wow my friend do you need Ghost Busters? er no this is mostly a case of the main switch being on lock, or the main IC going down on the panel in the cameras brain area, check the locks first, if it is the chip you will need to call your Sony repair man (He will love you) with summer coming he will be able to go on longer holiday, because that wont be a cheap mend sadly.
Number for help then is 01256 828828, now what you will do for cash for your holiday I simply do not know.
Take care, hope it gets sorted out okay?
Jun 04, 2010 | Sony Handycam CCD-TRV57 Camcorder
Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Aug 26, 2007 | Sony Handycam DCR-TRV10 Mini DV Digital...
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Should I use automatic or manual while recording?
Select RCA camcorders feature both an Automatic and a Manual recording mode. Automatic recording places the camcorder into Auto Shot™ mode. Focus, exposure, iris control, white balance, and the video light are controlled by the camcorder during Automatic recording. This mode is particularly handy for those times when you want to be able to just point the camera and record. The Manual recording mode allows you to control many of the elements above yourself, as well as many of the camcorder's special features including Animation and Time Lapse. Manual mode is also where you access the menus and set the clock. Make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode.
Sep 06, 2005 | RCA CC-432 Camcorder
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
41 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
