Question about Hoover F6021-900 Steam Vacuum
Need new hose
Where do you buy new hoses.? Does one size fit all?
  • 20 Answers
Posted on May 10, 2008
I need a Simpson EZI SET dishwasher inlet hose. I have been sent one but it is too short
take the hose along to a hose making shop ( any hydraulic hose manufacturer) and have a hose made to your length
or get your old hose , cut off the ends and use the fittings in a quality hose from your hardware shop
use hose clamps to fix the hoses back on the ends
Oct 20, 2016 | Vacuums
Why doesn't the shampooer dispense suds width of the tray
You need a new screen on your tank. It's the little tiny round plastic one that fits onto the tank where the hose plugs into it. (not the foam one) Yours may be wedged sideways in your tank hose (this is a common occurrence) If your screen is damaged (loose around the edge) you will need to buy a new one.
Jun 15, 2014 | Kirby G6 Bagged Upright Vacuum
Vacum is fine just no suction on attachment hose how to unclug hose
Hi there, I see this problem pretty often because where the hose joins the machine proper there is a slight reduction in airway size. I have made a video to show you how to remove the hose so take a look at that. If you find a split in the hose you will need to buy a new DC07 hose because it will reduce suction ans cause blockages more frequently.
Feb 12, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Got pipe out - can't get it back in
The pipe should have a plastic holder at the bottom of the hose, providing its still in tact.
If it is then do the following:
1 take the wand off the hose so the hose is bendy
2 the plastic holder at the bottom of the hose should slide in to the main body and clip in if you are still having problems take off the inspection valve where the hose fits in and then try again.
If the plastic on the hose is broken, then buy new hose.
Sep 18, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi - greetings from Scotland! Im not sure if you mean telescopic hose = do you mean telescopic metal tubes? If so they are readily available on I buy from many sellers on there but Hoovermania are one of the best.
What you need to do before order is to measure one of the smaller cleaning tools at the opening with a ruler where you'd usually put the hose. If you haven't got one to hand measure the end part of the plastic handle where the hose is where you'd usually attach the pipes. Generally if it measures 3.5 cm this works out to be a 32mm fitting tube which is readily available on Ebay and from different sellers. If however it is more then it has a 35mm fitting.
If its bigger than that, then you'd need 35mm tubes of which some are still available on EBay. In any case, you can look at different manufactures because when it comes to telescopic metal tubes the 32mm fittings will fit any vacuum cleaner that can accomodate these sizes. Therefore shop around; Hoovermania have a few on offer and you can phone / email them if you are not sure.
Mar 27, 2009 | Philips Vacuums
Hose for G3 Kirby doesn't fit Sentria
Yes G3 and G4 had different gasket thus the suction blower connector connecting Kirby hose to the unit on later models is different. You do not need to replace entire hose but just the plastic part that connects to the vacuum. You can find it HERE. To remove old connector you may have to submerge the end of the hose into hot water (not to hot to touch) so the vinyl becomes soft and you can bend it in with finger bringing plastic end over the lip on the molded end of the hose.
Good Luck
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I want to reconnect a hose to my dysons upright
You can find replacement hoses on eBay for the price of $20 to $30. Search for "DC07 hose". That, obviously is the easiest route. But, you can repair the old hose if the damage is near one end or the other of the hose. Damage in the middle of the hose will not leave enough length for effective use and thus buying a new hose makes since.
If you decide to repair the hose, you will need to use wire cutters to snip the wire in the hose below a point where the damage is and then use scissors or an exacto knife to trim away excess plasitic hose above the snip.
Remove the damaged hose section from the fitting that was cut off. You may need to use pliars to pull on the wire until it comes out. Check the inside of the fitting and remove any remaining debris so you have all of the grooves as clean as possible. The inside of the fitting is threaded like a nut and "screws" onto the hose. You will need some form of adhesive to help keep the hose attached to the fitting. I use silicone caulk for that purpose. Squeeze some into the threads on the fitting, screw the hose on and allow to dry over night.
Hope this helps.
Jan 18, 2009 | Hoover F5810 SteamVac Upright Vacuum
I have borrowed a kirby from my friend and i would like to wash my couches, please would you be so kind as to assist and let me know what tools i would need to use to be able to do so??
You need the upholstery attachment (it looks like a trigger sprayer with a plastic jar attached)You MUST have the foam screen that fits on the front of the trigger,without it,you will only get solution.The trigger sprayer fits on the end of the hose.The other end of the hose fits on the blower end of the machine.You must remove the bag,and attach the hose at this end.The trigger sprayer deposits the foam,and you work the foam in with a soft cloth or brush.When dry,switch the hose to the suction side,and vacuum out the foam.There is also an adapter (about the size of a styrofoam cup) that attaches to the front of the machine to allow it to be used when using the hose on the blower (bag) side.
Dec 14, 2008 | Vacuums
Hoover F6021-900 Steam Vacuum Logo
51 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
