Question about Peavey CS 1400 Amplifier
Peavey blazer 158 distortion on clean channel with speaker and headphones
  • 16 Answers
SOURCE: When I turn the power
Hi I have written two troubleshooting guides on the issues you have try them at http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Let me know if you still face a problem
Posted on Dec 13, 2008
SOURCE: I got a peavey rage 158 practice amplifier but it makes bad noise
er a *** my bro get new ****
Posted on Jan 09, 2009
  • 11 Answers
SOURCE: change the voltage from 240v to 120v
Unless there is a 240/120 switch on the back, this amplifier cannot change voltage. The only way is to replace the power transformer, and when you do that you need to use the exact model transformer Peavey uses for the 120 version. I have also seen differences in handling power outside of just a different transformer for USA/Euro models.
The differences between these two market models might be beyond what is cost-effective to convert.
If it is the Peavey blazer 158, they go for as cheap as 100 bucks here in the states. Or buy one new for 120.00 bucks and 4.99 shipping: http://www.dcmusicstore.com/Peavey-blazer-158-guitar-amplifier
Best advice: sell it for what ever you can get and buy one here.
Hope this helps!
-mike
Posted on Apr 01, 2009
freddyfreddy
  • 3 Answers
SOURCE: peavey minx 110 no output to speaker-headphone
LOUD SPEAKER BURNED REPLACE
FREDDY
TIGER ELECTRONICS LTD
ISRAEL
Posted on Nov 11, 2009
  • 5603 Answers
SOURCE: Peavey Rage 158 guitar amp
I don't believe there is a power "outlet" on this, only an "inlet".
Usually the inlet will have a lead, often green, that goes to the chassis.
There will usually be two other wires, often black and white that connect to the other two pins.
From the back of the connector, with the center pin tied to the grenn wire of the triangle lower, the pin to the right should be the white and the pin to the left is the black wire
Posted on Jul 25, 2010
I only have a vintage Peavey XR600B and I want to connect and ipod and ipad up to it so I can play music. Can I do this or do I need special cables?
Sure you can, but that mixer amp is a mono amp instead of stereo. Head for radio shack and get an 1/8" stereo male phone jack to 1/4" female mono adaptor. Plug the adaper into the headphone output of your device. Then run a shielded cable with 1/4" mono phone plugs on both ends (like an electric guitar would use) from the device to one of the channels on the Peavey. Bring the volume up on both the channel and master on the amp up maybe 1/3 the way. Play a track on your device and adjust the devices out put as high as it will go with out distorting the channel input. Then adjust the amp's channel and main output as you would normally to get the final volume you need.
Jun 28, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
One channel distorted on my peavey 1200 watt amp
Sounds like your output stage took a dump!
Dec 18, 2012 | Car Audio & Video
I have a HD 203 .. the right side speaker is not giving any output , the left is still working though...so do i have to change the speaker or the wire's or it useless and i have 2 through them awa
have a friend come over with their phones and plug in. if the same problem persists its the amp and it blew that channel. no problems then get new phones save old ones for parts.
Sep 16, 2012 | Sennheiser HD203 Headphones
Wires to main speaker are, Yellow & Blue witch one is the positive ?. Also I am getting distortion from the clean channel even at low volume, the speaker is Peavey 1230 model 8 ohms.
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Feb 21, 2011 | Peavey Bandit 112 Guitar Amplifier With...
If the master output lights go above green (into yellow) the sound becomes slightly distorted even at low speaker levels. i have cleaned the output jacks but it is still distorted
Does the distortion ALSO appear when you listen with headphones? If not, the problem may be downstream. The driver for the mute control line to the mute transistors may have a problem. Make sure the mute is off.
Nov 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Change the voltage from 240v to 120v
Hope this helps!
-mike
Mar 28, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Need the instructions for a peavey 158 Rage amp
Here is the link to the Peavey 258 Rage. The difference is the 158 is 15w and the 258 is 25w.
http://www.peavey.com/assets/literature/manuals/00583600_4.pdf
Dec 27, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
When I turn the power on on my Peavey blazer 158 guitar amp nothing happens. Is there a fuse?
Oct 13, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
247 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
shaqsatin
Level 1 Expert
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
