Question about Marvel (6SBARBSG) Wine Cooler
I have a marvel wine cooler and the bulb burnt out. My handyman removed a 10 inch component with a bulb (looks like the bulbs you find in a rope light) and a three prong connector. where do you get a replacement? thanks.
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
Krazytech
  • 725 Answers
SOURCE: Marvel model 61WC Wine cooler
first do you have power to the compressor? if not it could be a control... if you do it could be a relay...let me know and I can help
Posted on Sep 01, 2008
  • 51 Answers
SOURCE: frost is building in wine cooler
Check the door seals to make sure they are sealing good this can cause high humidity. The unit also seems to be getting to cold check with another thermometer
Posted on Sep 08, 2008
  • 101 Answers
SOURCE: Marvel wine refrigerator running,but not cooling
If your unit runs but does not cool, you have a "sealed system" issue. Either you are low on refrigerant which would be evident by frost build-up near the area where the freon first enters the evaporator plate. (lower middle, then travels left) or the compressor has lost the ability to develop the necessary differential pressure. You do not want to run the unit like that...you can **** in contaminants that will harm the compressor if you already haven't. You should contact a servicer to get it repaired. If you are still within the warranty period you should contact the dealer you got it from to initiate service.
Posted on Sep 15, 2009
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Can't figure out how to change the light bulb in my Wine Cooler? Can't get the plastic cover off? help!
Hello there,
How many techies does it take to change a light bulb (without a hammer)?
There is a tiny screw holding the lens cover in place. Once removed, the lens will come off and you can access the bulb.
Hope this helped
Thanks for using FixYa
Mike
Jul 24, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
What freon is in marvel wine cooler 61 WCMA
Don't know, but their should be a label on or near the compressor that tells you.
Mar 01, 2015 | Marvel (6SBARBSG) Wine Cooler
Where do I get the replacement bulb for a EWWC30MCG wine cooler? Can I order it from your web site?
If its one of the bulbs that looks like a small glass tube that has metal on both ends good luck! I tried to find a bulb for my cooler and you have to 100 of them , they won't sell just one.
Jul 21, 2014 | Furniture
Cooler does not come on. The lights work but does
If I read your serial number correctly, your 3.0 cuft Wine Cooler, was built 01-25-2001...there seems to be a digit missing. Your unit should have the SSAC control system which consists of three parts: The control board, the potentiometer and the thermistor. To verify this, you will need to pull your unit out so you can access the rear panel. Remove the bottom rear panel. Near the compressor you should find a 2-inch square control board that has 7 terminals and 4 small switches labeled 1-2-4-8. With the unit inplugged, disconnect the red wire from terminal #3 and the black wire from terminal #2 and connect them together. Plug the unit in. it should run continously. If it does run, then one or more of those three components is bad. If you have a multi-meter you can determine which one or you can order the set from the factory at 800-223-3900...part number 42246442.
Comment back if it does not run, or if there is no black control module or if you desire to test the individual components and I'll provide further assistance. - Subdriver
Feb 09, 2010 | Marvel 61WC Wine Cooler
Jan 28, 2010 | Marvel 61WC Wine Cooler
The light in my Marvel 3BAR cooler does not come on. The unit has power and is otherwise functioning well.
The 3BAR cooler has a 10-inch light bar that has multiple indicasent elements and is plugged in to the ceiling receptacle via a three pin plug. If you have a resistance/continuity tester you can unplug the light and check it for continuity across the two outer pins. (the center is ground). You can can also loosen the two screws that it the assemlby to the ceiling, remove the assembly and carefully test it with power. Most likely, it has burnt out. If the light checks good, then power must not be reaching the recepticle. Power is routed to the recepticle directly from the power cord via the door switch (when open) or from the ON/OFF rocker switch in the toe-kick. I hope this helps.
Aug 24, 2009 | Marvel (6SBARBSG) Wine Cooler
Relay
I truly doubt the control is the faulty component. It has two inputs it uses to decide when to cycle the compressor.
1) the potentiometer with the control dial is connected to terminals # 6 and 7.
2) the thermsitor is connected to terminals # 4 and 5.
Most of the time it is the thermistor that has failed. Marvel Part number 42244531.
You can order it directly from the factory by calling 800-428-6644
Oct 01, 2008 | Marvel (6SBARBSG) Wine Cooler
Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Refrigerators
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
Marvel (6SBARBSG) Wine Cooler Logo
89 people viewed this question
Top Marvel Furniture Experts
Sal DeAngelo
Joseph Hoffmann
Shehu Pro
Shehu Pro
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
