Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a look....thanks gerald gscrutch@yahoo.com
  • 33 Answers
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Posted on Sep 02, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Why wont my brush rotate no visible blockage
Start be replacing the belt and making sure the brush roll turns freely.
Apr 01, 2015 | Vacuums
Hoover F5915-900 brushes will not rotate
The motor rotates the bar. My guess would be that the rubber belt that goes from the motor to the belt has fallen off the bar , broke, or the bar is not seated properly. GOOD LUCK FRIEND.
Nov 13, 2014 | Vacuums
Why does my brush turn?
Most likely the belt that connects the motor to the brush has broken and needs to be replaced. A relatively easy fix.
Nov 12, 2014 | Shark 12-Volt Cordless Hand Vac
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
I have a volta ultima vacuum and the brush won't turn around anymore.
Tip the cleaner up and were the brush is theres a belt it is either slipping or broken replace. Undo cover over brush and undo brush lift out put new belt onto motor and then the brush and reassemble
May 17, 2010 | Vacuums
Brush won't spin. Put it back on the ribbed belt
Make sure the driving motor (power on) is turning (without the belt attached). Make sure the brush turns freely when the belt is off (it's probably jammed with wound-up hair, thread, and other debris--remove the brush and clean/lightly oil the bearings). Check the tension of the belt which should be fairly firm--replace if sloppy. Rotate the motor shaft by hand when everything is back together and make sure the brush can be driven without the belt trying to jump off. Hope this helps!
Mar 03, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Dec 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
BOSS 5851 Wide Track, 12 Amp
The top comes off to get to the belt and brush roll. Did you check the brush roll to make sure that the ends turn freely, or is one not turning, the belt is a lon life "U" part #61120A. The brush roll is what drives the vacuum, but if brush roll or belt is bad, then it won't drive it.
Feb 03, 2008 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
146 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
