Question about Grohe Home
We have 4 Grohe 28.432R body shower valves in use since 1987. One valve doesn't shut and leaks. Is there a cartridge that can be replaced. Thanks. Fred Novomestky
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 49 Answers
SOURCE: grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
Posted on Jan 23, 2009
  • 5603 Answers
SOURCE: I am installing a Grohe 35015 shower valve. I
Be concerned and follow manufactures recommendations. Often you make sure any plastic seats are not closed if soldering the valves.
The only connection for copper pipe I know of that aren't soldered are either the flared fittings OR the compression ones using the littl "ball" type collars.
Posted on Sep 22, 2009
SOURCE: How to clean cartridge in Delta Monitor shower valve
Found help in Delta website
Posted on Oct 02, 2009
Nomodo4u
  • 863 Answers
SOURCE: shower head is making high pitched whistling nois
The holes are probably clogged from hard water. Take the whole head assembly and dip it in a bucket of CLR for an hour or so. Then rinse off and give that a try. If your cheap, you can use a bucket of white vinegar and a little bit o water, but the smell is most disagreeable.
Posted on Feb 12, 2010
I have grohe 1000 shower and there is a constant water dripping from the head. What could be the problem
The water shut-off valve is leaking, thus not completely shutting off the water supply to the unit. Need to be repaired/replaced.
Mar 14, 2016 | Grohe Aquatower 1000 Shower System 27 016...
Just replaced Grohe wax cartrige 47 111 000, still have slow drip. HELP! thanks, James
besides the cartridge, the small brass screw/valve and its seat can cause this leak
Dec 10, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
I have a wireless Grohe shower that keeps dripping hot water constantly
Your mixing valve(faucet) has a bad valve and is allowing the hot water to bypass and leak thru shower. You should replace the bad mixing valve or the faucet to repair and stop the leak.
May 10, 2011 | Grohe Home
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
My moen model 3175 is leaking. What is the likely cause and how do I repair?
The cartridge is absolutely the culprit. Very good shower valve, however the cartridges do go. Shut the water, take the handle off, disassemble the face plate, remove chrome collar from body, remove retention split spring, pull cartridge itself straight out. Replace new cartridge in reverse order of removal. Cartridge can be found at home depot, or any plumbing supply store. Good Luck,
Steven
Oct 10, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Grohe shower. I want to adjust the temp mixing valve. I can not get cold water. It is always a mix-never pure cold. I want cold water. How do I adjust it?
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Jul 29, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    I have a Grohe shower head that leaks buckets (not an exaggeration). We bought the parts that we were advised to buy from Grohe, but even the professional plumber couldn't stop the leak or install the new...
    sounds like you need volume controls lots of grohe fittings are strictly mixing valves not shut offs if this valve use to work then you need to find plumber familiar with grohe
    Feb 21, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
    GROHE FAUCET DRIPS FAUCETS IS A 34-434
    yes this is definately the cartridge.You might not have to replace the cartridge.First take the cartidge out and see if their is any dirt causing the water to pass thru the spout.If thiers nothing obstructing the cartridge than you will need to get a new one.
    Jan 25, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
    Kindly
    Richie (UK)
    Dec 17, 2008 | Grohe Home
    Home Logo
    Top Grohe Home Experts
    Mike
    Oloyede Monsuru
    Are you a Grohe Home Expert? Answer questions, earn points and help others
