Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Freezer keeps freezing
Our freezer keeps freezing over i defrost it and adjust the tempeture controls but it still refreezes sfter 1-2 weeks causing the refrigerator side to heat up
  • Liz Touchet Jul 15, 2008
    i Have A Admiral side-By-Side, freezer Coils keep freezing And Refigoator Is Nor Cold,,I UNPLUG IT AND DEFROST IT AND IT WORK FINE FOR A FEW DAY,,BUT IT'S FROZEN AGAIN,,,AND SOLUTIONS,,REALLY NEED HELP,,THANKS
    President:
  • 1,314 Answers
You have a defrost problem pull the bottom kickplanel and look on the toe plate for a little piece of paper stuffed in there which will give you instructions for checking the defrost system if not reply to me ill se if i can find one for you
Posted on May 13, 2008
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
Where is defrost timer on amana arrccb
The ice in the ice tray freeze together as if they melted for a time then refreeze. It appears to maybe be a defrost problem. Can I adjust the defrost cycle on My Amana Bottom Freezer Refrig?
Nov 01, 2010 | Amana ARB224RCC Bottom Freezer...
Hotpoint HSS25GFP freezer side keeps thawing completely and refreezing causing freezer burnt food. what would cause this
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 15, 2010 | Hotpoint HSS25GFP Side by Side...
My freezer stays defrosted too long and melts all the ice, then refreezes causing icecycles
heatman101
Oct 13, 2010 | GE PSS26LGS Side by Side Refrigerator
Freezer thaws and refreezes daily
The would be a problem with the defrost sticking and staying on too long...change the defrost timer/control board out....
the defrost cycle is making the freezer warm and then it goes off and the freezer refreezes...
most times it fails the other way and does not work at all but sometimes this happens...
Howto Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Top of refrigerator is warm and bottom freezes everything it is a side by side refrigerator and the top two shelves of the freezer(along with the icemaker) thaw and melt but the bottom freezes and the top...
poss answer is drain hole/vent blocked,as unit auto defrosts water/vapour collects at bottom and when unit swiches back on it freezes,poke out drain with thin wire with a small piece of cloth dipped in clorine bleach or blow out with air hose.do not use hot water to manually defrost/ clean drain holes every 6 months
Feb 07, 2010 | Refrigerators
My Whirlpool side by side keeps freezing on the regular side.
your damper door is most likely frozen in the fully open position,thaw it out if iced up,then adjust cold control to see if it closes,the door is inside between the refrige and freezer compartments,also if this happens again check the door seals to make sure they are sealing good and not letting in warm air that can condense and refreeze this door
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator Making cold air, but not keeping food cold/frozen
Either defrost timer or Refrigerator thermostat, both located in the ceiling of the refrigerator, can give you long enough off times to actually cause thawing and then refreezing. Feel the rear wall of the freezer, half way down to see if a layer of frost has formed on it. This can indicate a problem in the defrost system which has three components.
The only way to be sure which of the two components is the cause would be to catch it in the thawing phase (not running). Tapping hard on the refrigerator temperature control knob can make it come on if it is the source of your problem. Good Luck
Aug 22, 2009 | Whirlpool ED2GHEXN Side by Side...
Hotpoint side-by-side freezer drain freezes
yes totally defrost unit and verify drain is not plugged, make sure drain is trapped. it may drain into a pan on top of compressor, where heat dissipated by compressor evaporates condensate. certain crosly model freezers made by w.c. wood co. have a problem with that.
Mar 30, 2008 | Refrigerators
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
130 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
