Question about Hayward Sp2807x10 Max-Flo 1 Hp Swimming Pool Pump
Hayward sp 2807x10 1 HP pump MAX water flow(GPM)
    President:
  • Hayward Master
  • 1,378 Answers
It is maxed out at about 75 GPM.
John
Posted on Sep 05, 2010
How can I verify that water flow rate to my Hayward H series heater is above minimum required 20 GPM?
Most pool pump/filter systems are designed to achieve the minimum recommended flow rate. A pump system with at least 1HP motor should achieve the minimum flow rate, but a 0.75HP motor would likely also achieve it. The Hayward H series heaters do not include a water flow rate sensor, but rather use a water pressure sensor to verify the pump is operating. If the system has insufficient water flow even when the pressure is within normal operating limits, the heater will likely over heat and open the water pressure relief valve located on the outlet header. This condition could occur if the down-stream line is blocked (by a closed valve or similar condition). It is important to avoid this condition since the heater will release pressure via opening a relief valve, spilling water directly out of the heater manifold.
The only adjustment for hydraulic sensing within the H series heaters is the water pressure sensor. See other articles within fixya for this procedure.
Jun 21, 2014 | Hayward H Series Pool & Spa Heater 400k...
What is max. gpm and pis of the wisperflo punp 011773
Your question sort of requires two answers as the max flow and max psi are not the same yet relate to one another.
The max flow is ~105 gpm at ~26 ft./hd or 11.3 psi.
The max psi (head) the pump can operate under is 40 psi or ~85 ft./hd at which flow is ~35 gpm.
In other words, in a pipe system with low resistance it moves up to 105 gpm and in a very complex system with lots of elevation changes and a lot of resistance the pump will move about 35 gpm.
PSI as read on a gauge on a filter attached to this pump will NOT be the same as the ratings I am giving you here.
John
Aug 24, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
PUMP SEAL LEAKING\r\nNEED REPAIR MANUAL
If you do have the Max flow the manual is here.
If not, find the correct model here and select it...then go to the manual page.
John
May 21, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
What impeller does the # Sp 2815x20 use
It uses the SPX2610C impeller. We sell it for $24.26 and have 2 in stock if you need one.
John
www.arrowpools.net
Sep 09, 2010 | Hayward Max Flo 2 H.P. Pump #Sp 2815x20...
1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Feb 20, 2010 | Hayward SAND FILTER, PRO SERIES
How do i remove the impeller from a self priming max-flow pump by hayward
Lock the shaft at the back of the motor and spin the impeller off counter-clockwise.
Oct 02, 2009 | Hayward Sp2805x7 Max-Flo 3/4 Hp Swimming...
HEATER GOES OFF ON EO2 OR EO4 CODE . WATER FLOW IS 145GPM HEAT EXCHANGER IS CLEAN FAN WORKS FINE. VENT PIPE HAS BEEN CLEARED OUT THIS IS A MINI-MAX 400 I RUN A FAN BLOWING ON THE HEATER AND IT STAYS ON...
EO4 is the heater fan error, it may go on briefly and then shut off after only a few minutes. most likely cause is a blown fan-there is a thermal switch installed on the blower fan that shuts off the fan when it gets too hot. the only workable solution is to replace the blower fan unit completely also 145 GPM is a very high flow rate; normal residential pools operate in the 40-70 gpm range and 110+GPM on commercial pools if this is residential you may have too much pump for your system. 1 1/2-2 hp is standard if you also run an automatic vaccuum off the same pump
May 07, 2009 | Pentair MINIMAX NT TSI IGNITER
Hayward Sp2807x10 Max-Flo 1 Hp Swimming Pool Pump Logo
316 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
