Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Blinking I JUST got my Krzr today and I was using it and in less than an hour it died on me and when I try to charge it, it just blinks on and off and will not charge.. I am using it on SunCom too. Do you know why it does this?>???
  • 55 Answers
I would put it on the charger for awhile (maybe 3 hours).
If it does not power on after that, your phone may need service.
Posted on May 22, 2008
I got a bytech bluetooth headphones a few days ago and the battery died after a few hours and now I've been charge it for over 8 hours and it still wont turn on when I unplug it.
Take it apart carefully and remove the battery, then replace it with a slightly larger Li-ion battery.(The headphones are built with Li-polymer batteries,lightweight,but not very efficient)
Sep 14, 2016 | Audio Players & Recorders
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully...
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
May 22, 2011 | Olympus Stylus / mju 1040 Digital Camera
Purchased Norelco shaver 7810XL. Instructions state to charge for 4 hours prior to first use. Green lights began blinking, indicating full charge, after less than 2 hours. Do I continue charging after...
Simply follow the instructions and charge for a full 4 hours the first time. On subsequent charges, unplug when the light blinks after about 1 hour
Dec 26, 2010 | Norelco Health & Beauty
I have a shoprider streamer sport and the battery drained all the way down today and died. Now it will not charge, the battery charger is blinking a green light
what you did you let your batteries die completely and you cannot let those batteries die like that. You might need to get new batteries.
Aug 29, 2010 | Health & Beauty
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
The menu light is blinking green and will only stay on about a second. Turns off before u can do anything
either your battery is dead or it should be replaced. try recharging the battery for 8 hours and check it again. it it doesn't work then check the battery's voltage level using a voltmeter. it its less than 5.3V and fast dying replace the battery.
Aug 14, 2009 | Polaroid i830 Digital Camera
Blinking LG Rumor Screen
Try letting the phone die by letting the battery run down. Then charge it back up and see if it will work. If not, you will have to take the phone into a repair center or store.
Jun 07, 2009 | LG RUMOR Cellular Phone
Car not starting, due to airbags blinking?
I had the same problem.air bag light blinking. Although the power window, radio, light, A/C,etc was working, I could not get it to start. I found out the charge indicator light was not coming on when key is turn to the on position. Cut a short story even shorter, The alternator died. Check your alternator, therefore not charging battery.. But first check your battery(all other features can still work with weak battery) Car can't start because not enough power in battery to turn over. That was my problem. Probably the same for you.
Mar 29, 2009 | 1997 Mazda 626
Macbook pro start up problem
First remove the battery, then plug it into your AC adapter. Hold the power button for 5 seconds or until you either hear and beep or the activity light on the front of your laptop lights up. Start up normally.
Aug 02, 2008 | Apple MacBook Pro Notebook
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
