Question about Panasonic KX-TG5110M Cordless Phone
When I try to pick-up the phone of the stand I get the following message: No link to base. Walk closer to base and try again. I am able to use my main phone, but only on speaker. When I pick up the phone off the base the phone disconnects. Help. Thanks.
    Genius:
  • 1,478 Answers
I will advice you try reset the unit first and see if it will respond to charging., Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if it fix the problem.
Take care.
Posted on Sep 01, 2010
How do I fix my phone?
Try another handset usually portable phones can have 2 3 or 4 handsets in the kit one is unusual if the second handset works then the phone is faulty usually the internal antenna cord has become dislodged which stops it being able to send or receive via the base
Solution 1 remove the battery cover & battery the remove the screws that retain the back cover of the phone & look around around for loose or dislodged connections.
Solution 2 get a 2nd hand phone off ebay (same make and model)
sychronise it with the base & if that works toss the faulty one
Solution 3 theses are relatively cheap Good Guys in Sydney
had Philips & Unident 3 phones & bases for under $50 recently
Solution 4 Get someone like me to repair the phone but it is likely to cost more than a new one to repair it, Pick a solution 1, 2, 3, or 4
Jan 11, 2015 | Lands Phones
No Link to Base - - Walk closer to base and try again --
You should try resetting both the base and handset but removing their power supply/batteries and then reconnecting their power supply/batteries. You can also check and see if there is a registration option on the handset that will re-link it with the base. Could just be broken though!
Jan 08, 2014 | Panasonic KX-TG2740 Cordless Phone
My panasonic kx-tg4321bx didn't give connectivity response rather than it gives a message "No link to base. Move closer to base, try again"
Well, you could move closer to the base, or try this: RE REGISTER the HANDSET. That works every time when our cordless goes stupid.
Carl
Sep 30, 2010 | Lands Phones
No link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
Feb 23, 2010 | Lands Phones
Our Panasonic system shows "No link to base walk closer" for any of the handsets even when 2 inches from the base. Seems the base has stopped communicating.
Often times when this happens try putting the phone back in the base unplug from the wall for about 30 seconds plug back in wait about a minute then try again. I have seen where you may need to also try unplugging the battery from the phone for a minute put it back in and place in the base. Its a communication problem with the phone to base connections and resetting the power often clears this up.
Hope this helps!
Aug 08, 2009 | Panasonic KX-TG2740 Cordless Phone
Phones have no dial tone and a message that says
Unplug base (both connections) and re-plug them again. It works for me whenever this happens.
Mar 17, 2009 | Panasonic KX-TGA560M Cordless Expansion...
Its saying no link to base,move closer to base, try again but the phone is right beside the base what do i need to do?
I also have no link to base message but only on one of my two handsets. One works the other doesn't.
Any suggestions?
Apr 15, 2008 | Lands Phones
No link to base move closer to base
Your getting this message because the radio portion of the handset or/and base is not communicating with each other. This can be temporary or fatal. You can try re-registering the handset(s) to the base by following the directions in the manual, its fairly easy to do for any model. If that does not work,and you have more than one handset not working with this problem, then it sounds as if your base needs repair or replacing.
Feb 04, 2008 | Panasonic KX-TG5632M Twin Cordless Phone
The phone ( sub-unit) links to the base on and off from time to time. How can I do ?
Sounds like the RF (radio frequency) module may be bad. If your battery is really old it could also be the problem, especially if the problem is more likely to happen after the phone has been off the charger stand for some time.
May 02, 2007 | Panasonic KX TGA270S Cordless Expansion...
Panasonic KX-TG5110M Cordless Phone Logo
43 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
