My monitor says "going to DPM mode" then nothing showing on screen
    Brigadier General:
  • 3,917 Answers
Hi
It seems RAM issue since DPMS stands for Display Power Management Signaling.
The first thing you should try is resetting the bios to the default settings. There is usually a jumper on the motherboard for this, but refer to your manual (available from the Gigabyte website) for details.
Secondly, try removing/rearranging the memory modules. You may find that one stick or one slot has gone bad.
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 03, 2010
When I turn on computer, the monitor say going to dpm mode. any help?
DPMS (Display Power Management Signaling) is a standard developed to save energy and maximize the useful life of computer displays. By switching the horizontal and vertical sync lines on or off, a DPMS compliant video card provides the capability to place the monitor into one of four modes (Normal, Standby, Suspend, Off).
Each mode puts the display into a different powered state from fully powered up, to the Off mode. In the Off mode, only a small auxilliary circuit is running which monitors the horizontal and vertical signals to wake up the monitor.
Dec 21, 2010 | Computers & Internet
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
LG LCD Monitor L1530S problems
Most screens will show nothing or go to power saving mode until the PC is turned on. The monitors need a signal in order to be 'active'.
From your description it could just as well be a problem with the PC rather than the monitor. The easiest way to find out is to connect another PC or laptop to the screen or connect another monitor to the PC unit.
Did you try pressing the Del key or F2 key when you turn on the unit to get into the Bios?
Jules
Jul 16, 2009 | LG L1530S 15" LCD Monitor
LG32LZ55 TV GOING INTO DPM MODE
Hi Ben,
Did you ever resolve? I have the same issue.
Jun 18, 2009 | LG Televison & Video
External monitor says laptop is in power save mode and goes blank
hey jkep
this has nothing to do with power, here is what to do
right click your desktop->
properties->
click the settings tab->
click the advance button->
click the display tab->
depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
Feb 13, 2009 | Acer Aspire 5610 Notebook
Unstable picture and EEPROM problem
Undo what you did & it should hopefuly work.
Next time don't be overconfident and do things that you are not sure of. It doesn't hurt to ask someone who knows. Here you are lucky to escape with this one. I've come across cases where people have ended up short-circuiting their gadgets beyond repair.
If you have the previlege of having a manual, refer it, read every word carefully and then go about doing things on your own.
May 05, 2008 | Gateway FPD2275W LCD Monitor
Monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Feb 21, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Black screen- undock the computer message
go to safe mode and return the settings back to day when it was all working fine. Use system restore.
Oct 30, 2007 | Dell E173FP 17" LCD Monitor
DPM Mode???
You might need to lower the resolution on your computer, the TV has a maximum resolution that it can handle, if you have it set too high you won't get a picture.
Jun 19, 2007 | Zenith Z15LA7R 15 in. HDTV-Ready LCD...
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
