Question about Health-O-Meter Health O Meter HDM520KD 18 Weight Tracking Scale
I have purchased a HealthoMeter Digital scale "the doctor's scale'. I put in new batteries, have it on a solid floor, and wait until it zeroes out. Once I step on it, it says E. Help. What can I do? Many thanks. Mary Ellen McWhirter mece2@san.rr.com Model HDL842-63
3 Suggested Answers
SOURCE: Healthometer Bathroom Scale
http://www.healthometer.com/Manuals.aspx
Posted on Aug 23, 2010
joeguest2
  • 2080 Answers
SOURCE: I lost my instruction manual
Look on the bottom of the scale for a sliding switch to alternate between Kg and lbs.
If you do not see one then remove the little cover and check inside the battery compartment for it.
Good luck.
Comment back here and rate with 4 Thumbs up if this was at all helpful.
Thank you.
Posted on Feb 23, 2011
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of ThinnerĀ® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you liveĀ® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
Need to reset them they are only weighing up to 7st 11lb and i am heavier than that thnx
if they are digital then turn them on and wait until the dial settles down
it should read zero (00000) stand on the scales and wait until it flashes and then stops at a weight
if it is still 7 stone it could be a battery problem or if they don't read 00000 before you step on them there may be a small screw that can be adjusted to get the first setting right
you can test the accuracy by doing something simple like putting a known weight on the scale ( 1lb of sugar -new packet ) and see what he reading is
keep adding known weights and if the multiples do not equal what is on the gauge reading then they should be returned if new of junked if used
Oct 01, 2015 | Cars & Trucks
My healtho meter scale says errl and won't reset.I put new batteries in but still get the same error
Underneath the scale there should be a tiny hole marked R or RESET.
Straighten a paperclip and press it into this hole for five seconds and that should do the trick.
If not, try this again but with the batteries removed.
Replace the batteries and switch on.
Apr 13, 2015 | Healthometer Health o meter HDM691DQN 95...
I bought a pierre cardin digital kitchen scale YHC1407C online including battery.is the battery inserted properly when u packed or should we insert it.the machine is not responding on pressing TARE...
If the scale is ''on'' then the battery is in correctly. ''Tare'' is used for making the scale read ''zero'' when a ''holder'' (such as a cup or plate) is placed on the scale and you want the scale to be at ''zero'' with that item on top of the scale. With nothing on the scale, the tare button will not do anything. Also, you have to hold down the tare button until the scale actually displays ''zero.'' (Perhaps you are just ''pressing the button'' and releasing it? You need to press and _hold_ the button down until the scale actually reads zero).
Jan 01, 2015 | Cameras
My health o meter doctor's scales model 230 will not balance at zero
Hi. Cldchasr is talking about an electronic scale, not your beam scale. Coachphil was helpful but inaccurate for this model. I have a 230. Use Coach's method but there is no screw on the left to adjust. Instead, use the black zero balance at the upper left. Move the black slide on the silver bar until the scale balances.
Aug 08, 2010 | Health-O-Meter 500KL Medical Scales...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Need to know how to adjust the weight
Try putting brand new batteries in and letting the scale zero out and then shut off on its own. Sometimes it's "zero" is misrepresented by an old set of batteries. Also, do any kids live in the house that might have jumped on it? If so, it would be wise to buy a new one as the sensitivity will be ruined for life.
May 08, 2009 | Elite Home Electronic Personal Bathroom...
Health-O-Meter Health O Meter HDM520KD 18 Weight Tracking Scale Logo
132 people viewed this question
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
His Example
Level 1 Expert
TheHCGInstitute
TheHCGInstitute
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
