Question about Sub-Zero 690 Side by Side Refrigerator
During a recent thunder storm, as my wife opened the freezer door of our Sub Zero 690 Dual Refrigeration System there was a "flash" inside the unit and the freezer bulb went out. I replaced the bulb but it still didn't illuminate. I tested the light switch and it is fine, however, there is no power across the two wires that connect to the switch. The refrigerator side and freezer side cool nicely. The refrigerator lights are fine. Is there a fuse or circuit breaker in the Sub Zero 690 electrical system If so, where are they? Thanks.
  • miked40 Sep 01, 2010
    I tested the power feed to the switch and 120V is not being supplied in the two wires going to the switch.
  • 11,896 Answers
There is not a fuse but their is a fusible link in the wiring. You will have to trace the wiring to find the fusible link.
Posted on Sep 01, 2010
  • 2,272 Answers
The bulb is controlled by light switch only. The switch is bad or there is loose connection on the light switch.replace the left light switch with Sub Zero Part # 3060140.Remove the light switch out and then properly reconnect the wires to their respective position and recheck if still same problem then it has to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Where is serial number located?
Hi J.,
Side by side models have a serial tag inside the top door hinge of the freezer section
  • Open the freezer door and look up by the top hinge
  • Hope this helps!
  • Thanks,
Feb 07, 2016 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690-temp
Have you adjusted your thermostat to try to get a bit colder?
May 16, 2008 | Sub-Zero 690 Side by Side Refrigerator
Door gasket Very hot and also metal strip very hot asa well
Check if condenser fan motor is running and condenser unit - it might be full of dust and lint - clean it! It is dangerous for both compressors if that fan motor has stopped working! These parts located on top behind that alluminum grill, on right hand side. Sub Zero refrigeration condenser cleaning - Read instructions here:
http://www.subzerolosangeles.com/how-to-clean-a-condenser-on-a-sub-zero-refrigerator/
Sub Zero refrigerator repair service and parts in Los Angeles
Jul 21, 2014 | Sub-Zero 690 Side by Side Refrigerator
690 series subzero freezer issue
Richard, what you are doing is ok for afew month. Your system is not broken yet. There could a variety of reasons. Wait until it breaks.
Nov 16, 2013 | Freezers
Sub zero 690 model if doors are not flushed right , my fridge door is little out think that is the reason flashing clean the condenser light comes after 12 hrs or so .The fridge is worth 10,000 so how can...
It is perfectly normal for the refr door on a side by side Subzero to stick out a little further than the freezer door. That light could mean several things. If you have vacuumed the condenser then you should call a repairman to look at it.
Oct 19, 2013 | Sub-Zero 690 Side by Side Refrigerator
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
I have sub zero 642 and my techinician says that I need a ice make valve replacement. He says it costs $495, does that seem accurate?
Sub-Zero a hallowed name in refrigeration, and the 642 side-by-side refrigerator/freezer unit is a landmark Yeah, it's that impressive. Dual refrigeration uses two compressors and three evaporators, I can tell you to never expect less than $300 for calling anyone to your home!
Aug 10, 2011 | Sub-Zero 642
Sub Zero side by side frig. side not cooling. Freezer works fine
There is a fan inside the freezer and possibly the fridge. It circulates the cold evenly throughout the unit. The fan may shut off with the door open so hold the door switch in to see if you hear the fan. It's behind the rear cover on the inside.
Sep 11, 2009 | Refrigerators
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
107 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
